Body stripe glue removing?
Old 08-26-2005, 11:10 AM
Dublin's Avatar
Anyone have an idea on what to use in removing the glue that held the factory body stripe. I had no problem removing the stripes with a heat gun, but it left patches of glue behind. I've tried laquer thinner (makes it slightly gooey), WD 30 (works a little better with massive rubbing), and reheating with the heat gun (makes an unbelievable mess). Any suggestions??
Old 08-26-2005, 11:14 AM
97Limited's Avatar
Hey Dublin;
When i removed my badges from my truck I used actual 'adhesive remover' I think the product i used was made by 3M. It just melts off the glue and doesn't harm the paint at all!! Just let it soak a bit!!!
Good Luck
Old 08-26-2005, 11:27 AM
AW1090's Avatar
Yup, I used the 3m stuff and goof off......they worked great. Just let them soak a bit before you go to it with a rag.
Old 08-26-2005, 12:14 PM
Dublin's Avatar
Thanks guys I'll try it.
Old 08-26-2005, 12:23 PM
Dublin's Avatar
Old 08-26-2005, 01:44 PM
Steveh29's Avatar
It's called 3M Woodgrain And Stripe remover. It's available at most body shop supply places and good auto parts stores.
Old 08-26-2005, 03:13 PM
Greg'sToy's Avatar
Goof Off works too!
Old 08-26-2005, 05:02 PM
4Crawler's Avatar
Here is what I did:
http://www.4crawler.com/4x4/CheapTricks/Stripes.shtml
Old 08-28-2005, 12:41 PM
Denk's Avatar
3M stripe removal tool. Works like a big eraser. Takes off the stripe and glue. Finish off with some goof off and rinse.
Old 08-28-2005, 03:20 PM
Dublin's Avatar
Stripes and glue are history, should've done this years ago. Thanks guys.
icentropy
09-16-2020 02:47 PM
09-04-2015 09:27 AM
80Truck
07-24-2015 03:12 PM
Johntom240
7
07-13-2015 12:18 AM
Quick Reply: Body stripe glue removing?
