Bearing preload
Old Oct 6, 2005 | 02:38 PM
runethechamp's Avatar
Question Bearing preload
So I might have to (don't know yet) replace my front axle bearings on my 94 4runner, but as long as I take them out I still bump into this problem. The half-crappy Chilton repair manual says something about adjusting the bearing preload to a certain force (not moment), but nothing about how to do it. Can anyone here enlighten me on how to do this?
Old Oct 6, 2005 | 02:45 PM
Ironmike4x4's Avatar
I'm not sure if it's any different with Toyotas but find out what the torque spec is then tighten it down and loosen the nut just until you can get the cotter pin (GM version) hole lined up, but make sure the axle can still spin freely without any sudden stopping, if it stops soon then loosen up the nut a bit more.
Old Oct 6, 2005 | 02:48 PM
eric-the-red's Avatar
I used these instructions for setting the bearings;
http://www.off-road.com/toyota/wheel_bearing.html
Old Oct 8, 2005 | 07:23 AM
4Crawler's Avatar
Yep, I use the same tighten-loosen-tighten procedue for mine:
http://www.4crawler.com/4x4/CheapTri....shtml#Rebuild
Old Oct 10, 2005 | 01:33 PM
Thanks for the info. Just picked up my Toyota Repair Manual, and that book is CHAMP. Bearing preload is also covered, with pictures.
ladybugRC
458
Aug 21, 2020 10:41 AM
83yotastockR
11
Nov 10, 2015 06:54 AM
Chicken12
Oct 14, 2015 03:54 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
