Help with 22re - running really rough
Old Dec 5, 2005 | 04:34 AM
GreenLeafYota's Avatar
95 4runner, 22RE
Just had engine rebuilt.
Got it running well, after replacing cracked fuel lines, setting timing etc etc...
Now after 400kms, something happened. I started up after a short trip and my truck started running like shiet.
- standing idle fell to 400rpm from 900rpm
- no power, could barely get to work this morning
- very loud burp in exhaust (sounds like a motorbike)
did a quick check of wires and cap, nothing seemed to be loose
This was an instant change ie running well when I shut off, runs like crap when restarted 15 minutes later
Any ideas?
Thanks
Old Dec 5, 2005 | 07:41 AM
Yota4runner's Avatar
Explain this burp in the exhaust a little better. Could it be a miss? whens the last time you changed your plugs and wires?
Old Dec 5, 2005 | 05:14 PM
tc's Avatar
tc
Did the timing slip? If the hold down was not tightened enough, it could rotate a bit leading to the symptoms you describe. Easy to check anyways...
Old Dec 5, 2005 | 05:53 PM
Rivalred's Avatar
Spark Plug Wires, Timing, etc?
Old Dec 6, 2005 | 08:58 AM
Thanks guys...
It was missing. Somehow one od the wires got cut in half. Thionk a rock or ice chip flew up through the engine bay as no skid plate right now.
Back to running like normal... well sort of
Colington
Mar 8, 2020 09:51 AM
nick b
Jul 11, 2015 04:38 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
bryan34w
Jul 6, 2015 05:53 PM
karbin
Jul 5, 2015 11:37 PM
