new slave, cannot shift out of neutral!
Old Nov 3, 2010 | 06:21 PM
sloRunner's Avatar
i just replaced my clutch slave as i new it was leaking for a while but it finally went on me. over the past year or so i had to top off the resivoir from time to time. a couple of the times, the reservoir was dry. so i relpaced the slave and had to adjust the rod going into the master cylinder because there was about 3/4" of play in the clutch pedal. now, 150 miles later, i cannot shift into any gear once again and my resivoir is still full. i cannot adjust the pedal anymore, it is at maximum extension. fluid is as clear as new fluid.
Old Nov 3, 2010 | 06:23 PM
waskillywabbit's Avatar
The obvious is did you bleed the system? Is your clutch bracket cracked or busted? Common problem on a lot of older Toyotas.
:wabbit2:
Old Nov 3, 2010 | 06:26 PM
sloRunner's Avatar
re:
yes i did. twice, just to be positive all the air was out. the bracket seemed fine. will take a look at in a.m. truck has 120k
Old Nov 4, 2010 | 11:17 AM
sloRunner's Avatar
bracket seems intact. when my friend presses the clutch down, the rod pushes that bracket, but not a whole of a lot. im thinking it was a defective slave even though it is not leaking or the master cylinder is bad since the reservoir ran dry a couple of times...
Old Nov 6, 2010 | 06:40 AM
sloRunner's Avatar
ok so if you mean the bracket that holds the clutch pedal, that is cracked. i have read other threads and based on what everyone else's problems are when this plate cracks, i believe that this is the problem.
Old Nov 6, 2010 | 10:33 AM
That Guy's Avatar
i had the same problem on my 93. ended up that 2 springs on my clutch disc had fell out.
Bourbonblues
Dec 15, 2017 05:43 PM
spiewaker
Dec 16, 2015 01:10 PM
shredder4286
Oct 1, 2015 01:09 PM
bradahman
Oct 1, 2015 09:24 AM
scheuvront1993
Sep 17, 2015 06:17 PM
