SR5 center console...
Old Nov 2, 2010 | 12:48 PM
808-3VZE's Avatar
What parts do i need for it to mount up in my 94 dlx x-cab? It's 5spd 4wd my truck. Lmk. Thanks!!!
Old Nov 2, 2010 | 04:42 PM
hgill's Avatar
Do you have bucket seats in the DLX cab? Obviously, Bench seat wouldn't work for center console.
The truck should have factory mounting holes for all the bolts, so a center console from a SR5 truck should fit no problems. You might need to do some drilling.
Old Nov 4, 2010 | 08:12 PM
808-3VZE's Avatar
Sorry! I meant to say shifter console not center console.
Old Nov 5, 2010 | 08:18 AM
aviator's Avatar
There are two brackets that attach to the floor ahead and behind of the shifters.
If you pull them out of a wreck you will find they are spot welded to the floor however a large flat screw driver and a little work with a hammer will break the welds fairly easily. The bracket may get a bit bent but it reshapes easily. It is pre-drilled and will naturally sit in place around the shifter housing in your truck. You can attach it to the floor with some short self tapping screws or if you have a friend some bolts and washers w/Ny-lok nuts. There is plenty of clearance below for either attachment method.
hope this helps
Old Nov 5, 2010 | 04:19 PM
808-3VZE's Avatar
hope this helps
Thanks!!! I'll make sure 2 get those brackets
Old Nov 5, 2010 | 08:18 PM
aviator's Avatar
Make sure you try for the set (ie one front and one rear) they are different.
Old Apr 18, 2011 | 05:29 PM
atari56's Avatar
Did the OP ever follow through on this? I'm purchasing the parts for the same mod and have yet to see it run through to completion on YT but I have a few questions and dont want to thread jack...
I will post my own thread once the new carpet comes in and I get started.
justdifferentials
Just Differentials
14
Sep 24, 2017 08:32 PM
Up&Down
Aug 5, 2015 06:20 AM
coffey50
Jul 28, 2015 10:55 AM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
HookahRoo
Jul 20, 2015 07:06 PM
