1985 4runner ebrake suggestion ?
Old Nov 9, 2010 | 11:08 AM
2003mikem's Avatar
I put a 4” lift on my 84 4runner and now when you put on the ebrake the “drum arm” hit the leaf spring and cannot pull on the shoe ?
Any thought how to correct this ?
Old Nov 9, 2010 | 11:13 AM
2003mikem's Avatar
no block 4" spring all 4 corners
Old Nov 9, 2010 | 11:22 AM
Outsane's Avatar
so the extra thickness of the springs is not letting the arm fully articulate?
Old Nov 9, 2010 | 11:25 AM
waskillywabbit's Avatar
Make a bracket extension. Piece of flat stock and drill some holes.
:wabbit2:
Old Nov 9, 2010 | 11:38 AM
2003mikem's Avatar
Originally Posted by razed
kay...
if the arm didn't hit the stock spring, it shouldn't hit an aftermarket lift spring.
it dose hit the spring pack. its thicker.
the lift spring is about 3/8 - 1/2 thicker
Old Nov 9, 2010 | 12:11 PM
Swimmerboy2112's Avatar
How about using a transfer case brake?
Old Nov 9, 2010 | 12:22 PM
good idea but not legal for e-brake use
I didn't know that. Hmm you learn something new everyday.
Old Nov 9, 2010 | 12:24 PM
xxxtreme22r's Avatar
doesn't someone make an extension bracket for this?
yup or make your own like the wabbit said:
http://www.4crawler.com/4x4/ForSale/...rakeExtensions
Old Nov 10, 2010 | 04:53 AM
e-brake laws basically state that the vehicle shouldnt move with that brake set.
with a trans brake the driveshaft could be locked but the differential could still let a tire slide.
so they want both wheels locked at one end of the vehicle.
if that were the case then you'd be able to have a x-fer brake and have either a spool or maybe full locker like and ARB in the rear and be legal.
Old Nov 10, 2010 | 05:07 AM
this is the way it's read in PA. Seems to me the x-fer brake is perfectly legal. At least in PA
Now if we are talking about line locks then no as it violates the part which states "The system shall not be designed to require a continuous or intermittent source of energy for full effectiveness after initial application."
References :
http://www.legis.state.pa.us/WU01/LI.../HTM/75/75.HTM
http://www.dmv.state.pa.us/pdotforms.../section_e.pdf
(c) Parking Brake System - A vehicle specified
under this subchapter shall be equipped with
a parking brake system. See 75 Pa. C.S.
§4502.
(1) A parking brake system shall be ade–
quate to hold the vehicle on a surface free
from ice or snow on a 20% grade with
vehicle in neutral.
(2) The parking brakes shall be separately
actuated so that failure of any part of the
service brake actuation system will not
diminish the vehicle’s parking brake
holding capability.
§ 4502. General requirements for braking systems.
(a) Parking brakes.--Every vehicle or combination, except a
motorcycle, operated on a highway shall be equipped with a
parking brake system adequate to hold the vehicle or combination
on any grade on which it is operated, under all conditions of
loading, on a surface free of ice or snow. The system shall not
(b) Service brakes.--Every vehicle and combination operated
on a highway shall be equipped with a service brake system
adequate to control the movement of and to stop and hold the
vehicle or combination on any grade on which it is operated,
under all conditions of loading, and adequate to meet the
braking performance standards established by regulation of the
department.
(c) Breakaway systems.--Every combination operated on a
highway, the towed vehicle of which is equipped with brakes or
which has a gross weight in excess of 3,000 pounds, shall be so
equipped that, upon breakaway of the towed vehicle, the towed
vehicle shall be stopped and held automatically, and the towing
vehicle shall be capable of being stopped and held by use of its
own service braking system.
(d) Exceptions.--This section does not apply to towed
instruments of husbandry and such items or types of special
mobile equipment or commercial implements of husbandry as are
specifically exempted from compliance by regulations promulgated
by the department.
Old Nov 10, 2010 | 05:38 AM
RBX's Avatar
RBX
Land Rover Discovery has a transfer case e-brake (drum)...perfectly legal in the U.S.
Old Nov 10, 2010 | 05:45 AM
Yep. It's a big honking drum too or at least the one on the D2 I worked on was honking!
:wabbit2:
Old Nov 10, 2010 | 06:13 AM
RBX's Avatar
RBX
^^^ i wonder if they use that large drum(i'm thinking rotating mass) to be calculated with the flywheel weight for proper engine braking/stalling?....Oh, nevermind, they aren't Japanese!
Old Nov 10, 2010 | 06:39 AM
Teuf's Avatar
Well I have one, and it works so far.
Old Nov 10, 2010 | 07:41 AM
Outsane's Avatar
How much is all this business ^??
Old Nov 10, 2010 | 07:48 AM
$367 plus shipping for the allpro kit
$195.00 plus shipping for the Sky Manufacturing kit. ( I think that's what Teuf has )
Old Nov 10, 2010 | 08:04 AM
Outsane's Avatar
holly crap!
Old Nov 10, 2010 | 10:11 AM
Teuf's Avatar
Yes it is from Sky Man. And it was 195.00. I did paint it. The only problem was that there was no caliper when delivered, a quick call fixed that. I am happy with its function. And I am aware of the open diff issue on say a hill in snow. No snow in Napa last I saw.
sandyota
Feb 4, 2021 11:16 AM
nanhodges2733
May 29, 2020 03:28 PM
Road Bull
Oct 10, 2015 04:55 PM
raiderhawks00
Jul 8, 2015 06:23 PM
bryan34w
Jul 6, 2015 05:53 PM
