battery draining
Old Nov 11, 2010 | 03:56 PM
jefferson82's Avatar
battery draining
Hi, so I just did the head gasket in my 93 4 runner 22re and now my brand new battery drains over night, Is the coil on my alternator drawing constant power? if so how do I fix it? I have checked all my fuses and everything is good. Any help would be appreciated
Old Nov 11, 2010 | 04:43 PM
BigBluePile's Avatar
The coill on your alternator? Huh?
Old Nov 11, 2010 | 07:43 PM
myyota's Avatar
Take your battery in and have it tested, if its good then pull the alternator and have it tested, either one of these could cause the problem your having. Even a new battery can go bad.
Old Nov 11, 2010 | 11:31 PM
wyoming9's Avatar
Red face
Could be you have something hooked up wrong.
Have you checked your battery in the morning with a meter.
I have seen bad grounds act like a low battery
Old Nov 12, 2010 | 04:40 AM
xxxtreme22r's Avatar
I had this problem once before and it was my cheap crappy radio that was drawing power when it was off for some reason.
Might be a crazy question but why would you check fuses for a power draw? If the fuses were bad there would be no power draw. Forget your this morning?
tazman1972
11
Sep 28, 2015 10:32 PM
toyotasaurus
Sep 24, 2015 03:30 PM
Boomer8404
Sep 17, 2015 07:59 AM
gp66
Sep 14, 2015 12:10 AM
Boomer8404
Sep 10, 2015 09:01 AM
