smog legal aftermarket carb?
I don`t think you will be able to find a smog legal after market carb, and if you did it probably still wouldn`t be legal because the vacuum lines going to it would be different and it probably wouldn`t pass the visual inspection.
the place i take it to wouldnt even know the difference honestly. as long as it passes the sniff test its all good
If that`s all they do, then the most common carb swap is a webber carb, from what ive read here most people see a nice increase in power and a gain in gas mileage.
if you do a weber conversion be ready to delete 90% of your emissions equipment. EGR gets deleted, as well as the PAIR system. PCV can stay as well as the crank case vent and the fuel tank charcoal canister.
Longbed 90
03-11-2019 12:38 PM
justdifferentials
14
06-11-2017 08:36 PM
22r, 86, aftermarket, california, carb, carberator, carburetor, carburetors, inspection, legal, pa, pass, performance, smog, swap
