smog legal aftermarket carb?
is there anything available? i dont like the stock one but i gotta keep it legal to pass emissions tests
I don`t think you will be able to find a smog legal after market carb, and if you did it probably still wouldn`t be legal because the vacuum lines going to it would be different and it probably wouldn`t pass the visual inspection.
Originally Posted by DROPT
(Post 51587348)
Originally Posted by myyota
(Post 51587423)
the place i take it to wouldnt even know the difference honestly. as long as it passes the sniff test its all good |
(Post 51587437)
well they dont really inspect it that well. they just make sure that its just running clean not putting out excessive hydrocarbons and what not.
if you do a weber conversion be ready to delete 90% of your emissions equipment. EGR gets deleted, as well as the PAIR system. PCV can stay as well as the crank case vent and the fuel tank charcoal canister.
