22re rough idle
Old Nov 7, 2010 | 08:35 PM
matt92yota's Avatar
22re rough idle
hey guys i have a 92 yota pickup with the 22re motor, it idles like it has a vacuum leak but ive replaced all the vacuum hoses and the egr valve and it didnt fix it. any ideas? please let me know your help would be very appreciated
Old Nov 8, 2010 | 07:27 AM
BajaRunner's Avatar
I'd check for vacuum leaks with an unlit propane torch. There are a few gaskets which could fail along the way: Throttle body gasket, Upper intake plenum gasket and lower intake gasket (attached to head).
Also its relatively common to find cracks in the intake tube that runs from the airbox to the throttle body.
Rough idle can also be caused by an inoperable idle air control valve and throttle positioning sensor.
Double check your TPS here:
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
Very simple, you just need an ohm meter and a few thickness gauges.
Then i'd go aand check valve clearance and timing. After all those check out, come back.
Old Nov 8, 2010 | 11:17 AM
matt92yota's Avatar
thanks for the help guys, it was a crack in the intake tube, replaced it today and shes runnin like new again!
Sleaker
Aug 26, 2020 06:03 AM
Eggslinger
Jun 8, 2019 03:32 PM
montanatruck
Feb 26, 2017 07:07 AM
Sep 4, 2015 09:27 AM
v_man
Jul 23, 2015 04:01 PM
