engaging choke? 22r
Old Oct 30, 2010 | 12:14 PM
DROPT's Avatar
engaging choke? 22r
How do i engage the choke on my 22r? or does it do it by itself? doesnt start as good when its cold. i thought there was a trick to it or something like pushing the pedal all the way to the floor to engage it?
Old Oct 30, 2010 | 01:32 PM
myyota's Avatar
The choke should engage by it self, push the gas peddle down and that should engage the chock. If its sticking or not engaging, clean the linkage with some carb cleaner.
Old Oct 30, 2010 | 01:57 PM
DROPT's Avatar
i figured it would do it by itself since its electric, i just went out and started it. and worked fine after pushing in the gas pedal.
Old Oct 30, 2010 | 05:28 PM
Romans117's Avatar
The choke is closed when cold. If the choke is not closed it will not start. When it warms up vacuum pulls it open. If you have the stock carb.
Old Oct 30, 2010 | 06:18 PM
yotaman90's Avatar
To engage the choke on a cold 22R with a factory Aisin carb, press the gas pedal fully to the floor two times. This is what my 1987 owners manual states, and it always worked for me
Old Oct 30, 2010 | 07:10 PM
Dr. Reddog's Avatar
Yotaman is right; 2 times all the way to the floor when cold, then turn the ignition with your foot off the pedal. When warm, don't pump at all, but have the gas half way down when turning the ignition. Sometimes if it's really cold I need to pump mine 4 times, but it always starts immediately for me. Once it's been running for awhile it might idle a little high; if so tap the gas about halfway, this will reset the choke and drop the idle back down.
Old Oct 30, 2010 | 10:24 PM
DROPT's Avatar
thanks guys, this is gonna save me some headaches when it gets really cold outside
Old Oct 30, 2010 | 10:40 PM
peow130's Avatar
x3, i do this every morning and it works.
Old Nov 8, 2014 | 05:19 PM
greaseball's Avatar
my choke was messed up by the p.o. just try to find parts like a choke coil you have to buy the whole carb new or go to a wrecking yard.
buckz6319
Aug 5, 2017 03:50 AM
Iceman4193
Oct 16, 2015 10:50 AM
alexcarey
Oct 14, 2015 06:05 PM
Toys4parts
Sep 26, 2015 01:56 PM
taraf
Sep 25, 2015 02:57 PM
