mass air flow
Old Jun 15, 2008 | 02:04 PM
boostedyota's Avatar
Question mass air flow
i have a 86 22rte pickip and is it true that you can take the plastic top off of your mass air flow and richen or lean it by messin wit some gears or wat????
Old Jun 15, 2008 | 02:47 PM
dcg9381's Avatar
yikes...
Note, the 22RTE may have a turbo specific AFM. The AFM is very expensive.
Many people have destroyed theirs by messing with it.
Yes, you can adjust mixture.
Old Jun 15, 2008 | 02:59 PM
mt_goat's Avatar
Are you trying to make it run richer or leaner?
Old Jun 15, 2008 | 03:33 PM
i am trying to make it run leaner. i am getting like 11 to 12 mpg and my air/fuel ratio gauge says rich
Old Jun 15, 2008 | 07:17 PM
4ランナー's Avatar
You'll actually be adjusting the Air Flow Meter(AFM).
Air deflects a flap in an enclosed space. More air coming in = more deflection of the flap. something is connected to the flap , and as the flap moves an electrical signal that is sent to the ECU.
Anyway you can adjust it to make it run leaner, the AFM is fitted with a flat-wound spring that applys tension to the flap. This spring is adjusted with a plastic gear and a wire holder. When this gear is tightened (turned clockwise) relative to the flat wound spring inside of it, it becomes harder for the door to open, and this translates to a leaner mixture (more air needs to flow in to move the door by a given amount, maaning that the mixture is leaner relative to its starting point before adjustment). Turning the gear counter-clockwise has just the opposite effect, as the looser gear lets more air in relative to "stock".
Turning the gear CLOCKWISE LEANS OUT THE MIXTURE.
Turning the gear COUNTER-CLOCKWISE RICHENS THE MIXTURE
Each tooth of the gear is equal to ABOUT a 2% change in the transient mixture
Dunno where I got this info but it was saved randomly in notepad as "need"
Also id probably mark the stock postion of the gear so not to lose track of your adjustments
Old Jun 16, 2008 | 09:18 AM
dcg9381's Avatar
AS I indicated on the turbo forum - check your o2 sensor first. You should dither at cruise.
Old Jun 16, 2008 | 09:59 AM
BigBluePile's Avatar
Here, good luck:
http://www.4x4wire.com/toyota/minutemods/afm/
Old Jun 16, 2008 | 09:32 PM
about how much should i tighten the screw like 1/8 or what?????
Old Jun 17, 2008 | 03:25 AM
mt_goat's Avatar
What's your air/fuel ratio been running exacty (numbers)?
Old Jun 17, 2008 | 08:05 AM
norcalsvx's Avatar
just go one click at a time its real easy to adjust.
Doug4320
Mar 24, 2018 10:11 PM
RatOmeter
Oct 22, 2015 03:17 PM
markf1
Sep 3, 2015 01:23 AM
4runnerstalls
Aug 26, 2015 11:13 PM
bighaydn
Aug 4, 2015 07:17 PM
