87 22r help. running rich
Old 06-06-2008, 08:36 AM
natecr's Avatar
well i have an 87 toyota 22r 4x4 pu
the motor has a problem it likes to backfire in between shifts and is defintly running rich.
what are the things i could do or check. im new to toyota not to cars. im used to working on jeeps and such just need some help thanks guys
Old 06-06-2008, 05:18 PM
abecedarian's Avatar
is your check engine light on?
you said 22r, not 22re so timing, vacuum leaks, ignitor, caburetor, air-injection system.
Old 06-06-2008, 06:39 PM
CyMoN's Avatar
mine did the same thing I almost positive it was the fuel cut solenoid on the carb that and the choke had been messed I found a used one at the Upull for 20$ it solved my problems but now I have other minor ones I am trying to figure out.
Old 06-06-2008, 10:56 PM
natecr's Avatar
it was a vac leak.
i un hooked the hose that goes to a valve that controls this 3/4in hose that has vac that goes to the air cleaner and it stopped backfiring and running as rich so im assuming there is a vac leak somewhere and this is a temp fix till i find it. any ideas?
Old 06-07-2008, 11:54 PM
natecr's Avatar
is there any popular places for the motor to lose vac?
Old 06-08-2008, 05:25 AM
grab a can of wd-40 or similar and spray in short bursts on the hoses when the engine is running. the engine speed should fluctuate when you spray near a leak.
Old 06-09-2008, 03:05 PM
natecr's Avatar
still running a bit rich and it is missing a bit too..
compression is within 15psi from each other with the low being 150 is that OK?
but i dont know where to go from here i know its running rich and i have checked all the vac lines.
Old 06-09-2008, 03:20 PM
you mentioned the diverter valve- it has the vac hose and 3/4 hose that goes to the filter... it's possible that it is malfunctioning or the vacuum switch that controls it is. air-pumps / air-injection systems are notorious for causing backfiring when they malfunction.
also, isn't there a dashpot on the carburetor that keeps the throttle from quickly slamming shut when you let off the throttle? I believe part of it's function was to prevent backfiring.
Old 08-22-2008, 08:42 PM
DOLO's Avatar
bumping for results:
my 90 22R is doing the same thing and I'd hate to burn up the valves since I just got the truck.
Old 08-22-2008, 08:44 PM
90 22r? do you mean 22re?
Old 08-22-2008, 08:47 PM
DOLO's Avatar
nope. 22r.
Old 08-22-2008, 08:58 PM
where are you at?
Old 08-22-2008, 09:05 PM
DOLO's Avatar
I'm in Hawaii. btw, it's a 2wd. My 89 4wd is 22re.
Old 08-22-2008, 09:13 PM
didn't know you could get a carbureted toy in the US in 90.
my bad.
Old 08-22-2008, 09:20 PM
DOLO's Avatar
That could be true for mainland U.S.. I'm not sure about Toyotas but I know that here in Hawaii, Suzukis and Hondas came straight from Japan market. That may be true for Toyotas too. I know once I contacted Suzuki MotorCorp for a paint code for my bike and was referred to their offices in Japan.
I guess it's cheaper to ship from Japan than it is from mainland U.S.
Old 08-22-2008, 09:22 PM
DOLO's Avatar
back to topic:
someone mentioned the air pump/ air injections system. How would I go about checking that?
Old 08-22-2008, 09:26 PM
paint is not the same as smog.
Old 08-22-2008, 09:28 PM
Originally Posted by DOLO
back to topic:
if it is carb'd, find a diagram for a late 80's carb'd truck with the air pump. there is basically a diverter valve that either puts the air from the pump into the intake or exhaust depending on engine vacuum.
Charecter1
11-06-2023 10:08 AM
sandyota
02-04-2021 11:16 AM
Eggslinger
06-08-2019 03:32 PM
87blyota
07-10-2015 04:31 AM
bryan34w
07-06-2015 05:53 PM
Quick Reply: 87 22r help. running rich
