waterlogged starter?
Old Jun 11, 2008 | 09:44 AM
nate9207's Avatar
well i finally got my 1990 yota truck fixed and it drives smooth as silk now. I went muddin yesterday and got my front tires stuck down in a mudhole that was really thick clay stuff. man that sucker was nasty. but now to the point, i heard that the starter is in a bad spot on these trucks and i think its got alot of mud and water buildup but i'm not sure cuz i havent had time to check it. has anyone else had this problem? my battery is fine but when i turn the key it just clicks. after about 30 tries it cranks right up but has the same problem the next time ya crank it. is there a way to prevent this from happening? like some sort of modification i could do in order to prevent it? any help would be greatly appreciated. THANKS!!
Old Jun 11, 2008 | 09:52 AM
904_runner's Avatar
I would take a look at the contacts and see if they are caked with mud, possibly take the starter out and test it.
grovedogg's Avatar
maybe check the connections and bolts holding the starter , if you were muddin pretty hard, something may have gotten jarred loose...
Old Jun 11, 2008 | 09:53 AM
4Crawler's Avatar
See below for some troubleshooting and repair ideas:
- http://www.4crawler.com/4x4/CheapTri...shtml#EasyTest
- http://www.4crawler.com/4x4/CheapTri...l#OtherOptions
Old Jun 11, 2008 | 01:14 PM
Snotrocket's Avatar
Check the battery connections first.
I replaced my starter this past weekend and got the same click with the new one.
My brother came over and took apart the battery terminals and had it running in 5 minutes.
Old Jun 17, 2008 | 04:05 PM
jdw1's Avatar
the old pickups are bad about that. when you go through water the points get corroded. get a piece of rebar or something metal and hit the starter about three times and i can almost gurrantee it will start.
Old Jun 18, 2008 | 08:04 AM
nate9207's Avatar
well i just decided to take er to the ol' autozone and they hooked it up to the tester and 3..2..1.. a big red light came on so i just got a duralast with a limited lifetime warranty. sucker cranked right up after i put the new one on. if it messes up again i'll just get a new one... for $FREE.99
ladybugRC
458
Aug 21, 2020 10:41 AM
pickle6415
Oct 19, 2015 08:08 AM
zombie_barbarossa
Oct 2, 2015 10:54 PM
bradahman
Oct 1, 2015 09:24 AM
beltcutter
Sep 30, 2015 06:14 AM
