Clunking noise
Old Jun 8, 2008 | 07:32 PM
TomkiRider's Avatar
Clunking noise
after wheeling a little bit i started hearin this weird clunking noise comin from underneath. its only when its in 4x4. it sounds liek its every time the driveline goes around. any ideas?
Old Jun 9, 2008 | 12:37 PM
Crawdad's Avatar
Busted U-joint, probably. Do you have manual or ADD hubs?
Old Jun 9, 2008 | 03:25 PM
TomkiRider's Avatar
manual
Old Jun 9, 2008 | 03:46 PM
abecedarian's Avatar
front diff support bushings maybe? differential itself?
inner cv shaft joints?
Old Jun 9, 2008 | 07:49 PM
TomkiRider's Avatar
no sont think so cuz 4x4 still works
Old Jun 9, 2008 | 07:55 PM
"don't think so" doesn't mean "I know not so"
you're saying that the noise occurs when 4wd is engaged, so that implies that the problem is in front of the transfer case. so what turns and what can make noise when that happens?
Those things are your primary culprits.
Old Jun 9, 2008 | 08:48 PM
TomkiRider's Avatar
K ill take a look 2moro afternoon. thx
Old Jun 10, 2008 | 08:49 AM
dirtoyboy's Avatar
Whens the last time you serviced your u-joints?
I service mine at every oil change
Old Jun 10, 2008 | 09:29 AM
CyMoN's Avatar
I re grase mi jonts evry tim igo ofrdng
chk ur frnt drv saft u jnts
AND use complete words quit being lazy if you want help solving your problem please show courtesy to spell out every thing out some people do not under stand.
you will get more responses in complete sentences the broken english.
and nice looking truck in the profile
Old Jun 10, 2008 | 03:41 PM
TomkiRider's Avatar
k i DEFINATLEY know the problem now lol. the front left axle is popped out. it doesnt seems like its broken just like popped out or somethin. sorry if thats not the right term im not good with technicals
Old Jun 10, 2008 | 05:02 PM
TomkiRider's Avatar
is that possible for it to pop out or am i just retarted and its broken?
Old Jun 10, 2008 | 07:10 PM
TomkiRider's Avatar
k so theres 3 round things that go into the truck part and is coming from the wheel part. the seperation is at the rubber boot. the pic is of one of 3 washers? that go on the round things, i had to drive the truck today so i think i lost the 3rd one on the road. how big of a fix is this?
http://i296.photobucket.com/albums/m...der/washer.jpg
Old Jun 10, 2008 | 07:22 PM
DIHOWARD's Avatar
CV joints usually have 3 round "thingies" and are housed in a rubber boot.
Old Jun 10, 2008 | 07:26 PM
TomkiRider's Avatar
lol alright thanks so i broke the cv joint. how big of a fix?
Old Jun 10, 2008 | 08:38 PM
the cv joint with the 3 round thingy's is usually refered to as a tripod joint. it's the 'inner' joint on the cv shaft, and actually the part least likely to wear since it doesn't deal with the extreme angles that the outer joint does.
Old Jun 10, 2008 | 08:45 PM
CyMoN's Avatar
some one posted up a how to replace the CV thread the other day I did one on a camey last week it was a 2 hour job next time I think I can knock it down to a hour.
it seems to be really close to the same as the trucks get your self a flat pry bar to pull it out at the diff getting the new one back in was the hassle getting the C clip to snap in was a pain.
don't rush take your time.
Old Jun 16, 2008 | 07:32 PM
TomkiRider's Avatar
l im gonna pick the part up tomorrow and a friends gonna help me put it in. any tips?
zytra
Jan 24, 2019 03:16 PM
Davebarbier
Nov 3, 2015 03:28 PM
zombie_barbarossa
Oct 2, 2015 10:54 PM
Odin
Sep 26, 2015 06:56 PM
