How do I hook up VSV in 3.0?
Old Jul 22, 2018 | 04:12 PM
Toyrusto's Avatar
I bought a used A/C system and am trying to hook up idle up vsv in my 1992 Pickup 3.0. I see where it plugs in but there is no place I see to attach the two vacuum lines.
I checked Google but could not find anything. The manual says one goes to the actuator and one to intake. Do I need to T into existing lines? Thanks!
Old Jul 22, 2018 | 07:06 PM
scope103's Avatar
I assume you mean that you don't see where to hook up the vacuum lines THAT COME OUT OF the VSV.
One connects to a larger (14mm?) tube which runs under the plenum to connect to the air cleaner. That tube is "Y"ed to the power steering idle-up VSV. The other line connects to a "Y" fitting into the plenum, just above the source tube. I have no idea if Toyota installs the appropriate under-plenum plumbing when you don't have factory A/C.
vsi1600
Apr 21, 2015 08:06 AM
Bob_98SR5
Apr 3, 2003 04:11 PM
ScottSE
Mar 30, 2003 04:34 PM
BTOWN4RUNNER
7
Mar 19, 2003 02:49 PM
HBoss
Jan 4, 2003 05:19 PM
