Help with location of 3vze coolant drain plug
Old Jun 27, 2018 | 01:40 AM
quevedofredy's Avatar
Hello everyone, I am a toyota pickup 3vze 1991 MT 4x4 owner, I am looking for the coolant drain plugs, fsm says that there are two plugs on each side of the engine block, I have a picture for one side but I am not sure if the bolt which I circled is the right one. Can someone help me to figure out if this is the correct one? Does anybore has a pic of the other plug located on the passenger side? Thanks.
Is the bolt inside the red box the coolant plug for 3vze driver side?
Old Jun 27, 2018 | 02:54 PM
scope103's Avatar
That is the correct plug. It appears to be brass (or at least brass plated.) I have one on each side of my 3VZE (and yes, they are hard to see).
Old Jul 11, 2018 | 02:51 PM
mkivbren's Avatar
I pull the oil cooler hose since it sits lower than the block plug.
tarra.dactyl
9
Apr 20, 2017 10:21 AM
John Peters
12
Nov 29, 2013 01:14 PM
dkyleb
May 14, 2011 09:33 PM
bluehair
Jul 26, 2010 07:44 PM
Zelephant
Dec 9, 2009 07:23 PM
