Back Up switch - too short
Old Jul 6, 2018 | 07:26 AM
CBGyota's Avatar
91 pick up - replaced trans with remanufactured w56b - did not come with reverse light switch. went to 5 different auto parts stores including Toyota and they all give me the same switch that is about a half inch too short. The fill plug that came in the reman has the plunger ball on the end but no plug for wiring. Any help finding a fit would be greatly appreciated.
Old Jul 6, 2018 | 02:33 PM
wyoming9's Avatar
Red face
The fill plug is not the place for the back up light switch
Take a picture of what your calling the fill plug .
If you do indeed have the correct hole and none of the switches work did you forget pieces from your old transmission .
Something not spaced correct on the rebuild??
Old Jul 10, 2018 | 08:18 AM
CBGyota's Avatar
Thanks for the response wyoming9 - I called it the "Fill plug" but what I meant was the plug they used to fill the hole where the back up sensor should be. Here in VA, I found out that if I remove the reverse lights (bulbs & socket) it will pass inspection....so that's what I did. I believe you are correct that something internal on the rebuild must not be in line to depress the switch to activate the lights. But for now, I'm calling this fixed!
RAD4Runner
May 3, 2026 08:50 AM
AmirK
Oct 25, 2017 05:23 AM
kcrunner
Jul 17, 2008 09:14 AM
Writeups@YotaTech
Jan 11, 2007 08:29 AM
Memphis4X4
Oct 10, 2003 11:40 AM
