3vze leaking bad
Old Jul 12, 2018 | 11:41 PM
Yodes's Avatar
3vze leaking bad
hi guys, ive been having bad coolant problems for a while replacing one part or the other, i was driving around with it leaking for a while now replacing fluid untill the last day it heated up almost to the red... when i pulled the rad cap off the next day it started steadily dripping from what seemed like my thermostat housing. replaced my thermostat housing gasket, the last one i put in had a crack right through. the new one i made was a good fit tightened her back up and started filling the rad but still pouring out fast. almost looks like its coming from above the thermostat rather than the housing itself. what else could this be? really need my truck back
Old Jul 13, 2018 | 08:11 PM
RustRunner89's Avatar
Just pulled this photo off the interwebs. You think it's your water pump that's causing the leak? I've read a few threads where that seems to be the case.
primordialbeast117
Dec 19, 2015 12:23 PM
Tk151
Jan 26, 2015 01:34 PM
MikeKaduce
May 27, 2006 10:30 AM
UNR.Grad
25
Jul 11, 2004 07:36 PM
