Help broke down while mudding
Old Oct 6, 2012 | 09:38 AM
thezrutherford's Avatar
After a day of pulling out fords and Chevys with
Y 1990 4runner I went through one last time and as I was exiting the hole I heard a loud pop and smelled clutch and started smoking I cannot get it in gear an I hear a noise under the drive side cannot get the car into gear without turning it off please help
Old Oct 6, 2012 | 10:28 AM
bjlambert's Avatar
Maybe you shouldn't have been so cocky and took it a little easier on your runner haha. Chances are you blew out the slave or tore a line off the trans, or just screwed the clutch altogether. That happens when you ride the clutch all day.
Old Oct 6, 2012 | 10:47 AM
DIHOWARD's Avatar
Yep, no good deed goes unpunished. X2 on the slave part, sounds like the clutch is not disengaging.
Old Oct 6, 2012 | 12:53 PM
Yeah I put it to the test so it you think it was the slave ? I couldn't get it in gear at all
Old Oct 6, 2012 | 01:18 PM
arlindsay1992's Avatar
Have someone press and release the clutch pedal while you crawl underneath and see if the clutch fork actually moves. Then you'll know if it's a problem with the hydraulics or the clutch assembly itself.
Obmi
Oct 4, 2015 11:30 AM
puddlepirate
Sep 29, 2015 08:02 PM
Toys4parts
Sep 26, 2015 01:56 PM
mtrdrms
Sep 26, 2015 07:12 AM
tysen86
Sep 25, 2015 11:15 PM
