Emergency brake equalizer
Old Oct 20, 2012 | 07:32 PM
26554's Avatar
I have had to strip my rear frame section to address some frame issues. Due to rust I had to replace my brake drum backing plates, my bellcranks have been rusted open for years. My question is the e-brake equalizer is stationary. I believe it must move to be effective. Is there a load recomendation on the movement of the equalizer?
Old Oct 21, 2012 | 01:49 AM
wyoming9's Avatar
Red face
The hardware holding it down has bushings I think nylon or something along those lines.
There is also a lock nut on the bolt .( A normal nut and lock washer will be to loose and vibrate off or to tight to move) The lock nut says in place while allowing the equalizer to do it`s job.Which is to move freely by hand with the cables disconnected.
If you went to all this much work trot over to your local dealer and buy all the new parts . Much easier then bringing life back to old dead ones and not all that expensive.
Old Dec 3, 2012 | 07:21 PM
SlightlyWhat's Avatar
So...what would be the worst case scenario if I pulled the E-brake and I hear it break? I hope it's easy to replace those lines...
E-break officially broken.
Old Dec 3, 2012 | 11:16 PM
wyoming9's Avatar
Red face
The rear cable is pretty easy.
The front cable can be interesting the first time
changing the bell crank brackets is interesting .
All this stuff can be fixed just take your time.
Old Dec 5, 2012 | 06:35 PM
Rgr.I hope rockauto has something. or everything.
okamikai
Apr 30, 2018 10:19 PM
old87yota
Sep 9, 2015 12:39 PM
Scatterbrain
Sep 3, 2015 06:46 PM
bfmcelroy
Aug 18, 2015 06:42 AM
dropzone
Aug 11, 2015 05:16 PM
