Unhooked speedo got code 42,43
Old Oct 17, 2012 | 02:14 PM
brianh699's Avatar
I unhooked my speeding because it was bouncing so much I was worried I may damage the gauge. I got a check engine light, pulled the codes. Code 42 makes sense no input from vehicle speed sensor, but I also got code 43 no starter signal to ecu. Truck starts and runs fine. I'm confused how unhooking speedo would cause this, although it could've already been stored, does code 43 illuminate CEL?
Old Oct 26, 2012 | 02:16 PM
dzldust's Avatar
I have a code 42 as well , can't trace it down .my speedo does not work as well
Old Oct 26, 2012 | 02:30 PM
brianh699's Avatar
Code 42 is speed sensor code, if u have a cable speedo it's unhooked or the cable is broken, if u don't have a cable it then the speed sensor on your transfer case may be bad.
Old Oct 26, 2012 | 04:20 PM
dzldust's Avatar
just checked ,my speedo cable is broke at t-case.....
Old Oct 26, 2012 | 05:01 PM
scope103's Avatar
IF you have a cable speedometer, VSS1 is in the combometer. So if your speedometer is not working, VSS1 is generating no signal, and you will get code 42.
IF you have the electronic speedometer, VSS1 is in the back of the transfer case, and the signal from that sensor drives both the speedometer and the ECM.
Old Oct 26, 2012 | 05:04 PM
dzldust's Avatar
without the VSS1 getting a signal will that throw off the ecm as to cause a stumble or power loss?
Old Oct 26, 2012 | 05:41 PM
brianh699's Avatar
I don't think so, I've had mine unhooked for a few weeks now. I get a check engine light every time I drive it (although it's always off when I start the truck ) I have no loss of power or hesitation because of it though.
Old Oct 27, 2012 | 12:02 AM
vital22re's Avatar
totally a bro
Keep in mind that your ecu recieves that speed signal from the dash. I dont' know what it does with that signal, but it uses it for something.
moparbay
Oct 6, 2015 09:24 AM
bradahman
Oct 1, 2015 09:24 AM
beltcutter
Sep 30, 2015 06:14 AM
charlie_fong
Sep 27, 2015 10:06 PM
Odin
Sep 26, 2015 06:56 PM
