4runner 3vze will run briefly.
Old Oct 17, 2012 | 11:18 AM
wcasey5's Avatar
Finished my head gasket repair, got the engine together and the truck will start, run for a second or 2, then die. Almost like there is a sensor that makes it run that isn't picking up. Any thoughts?
Old Oct 17, 2012 | 11:53 AM
scope103's Avatar
The fuel pump isn't running after you let go of the key. The problem is in the COR circuit or the VAF (which is part of the COR circuit). You can diagnose it by jumpering FP to B+.
(You did reconnect the air intake, didn't you?)
Old Oct 17, 2012 | 12:02 PM
wcasey5's Avatar
ahhh, no I didn't hook up the air intake. will do that. You suggestion sounds like a winner.
Old Oct 17, 2012 | 06:05 PM
wcasey5's Avatar
hooked up the intake and away it went. It idles rough and I have a vacume leak, but I can get that sorted out. Thanks a million!
zd92655
Mar 6, 2022 12:58 PM
JF9243176
Oct 8, 2017 04:21 AM
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
WI Girl
Jun 25, 2015 03:45 AM
newzingo
Jun 24, 2015 01:50 PM
