Add a leaf or new springs?
Old Oct 18, 2012 | 07:34 PM
Bchev's Avatar
I have a 91 pickup 4x4 and the rear leaf springs are what you'd expect from a 21 year old truck. My back passenger spring is pretty much flat and the back of the truck sags a little on that side . As of now I can only carry 400-500lbs in it without them completely just touching the frame. My question is should I just buy new leaf springs all together or are the add a leaf systems enough to fix the sagging problem and allow me to carry more weight? Thanks in advance.
Also if anyone has had good luck with the add a leaf systems what did you use? Or what does anyone recommend for new springs?
Old Oct 18, 2012 | 07:46 PM
dropzone's Avatar
Fossilized
Personally I would replace the rear springs.
Some have had luck with the Zuk mod.
Tons of info on it..give the search a try.
Old Oct 18, 2012 | 07:49 PM
cman1's Avatar
big fan of the ZUK mod!!!
punks_is_4x4
May 31, 2016 06:03 AM
Daenerysdad
Oct 1, 2015 07:33 PM
Kreedy1
Sep 8, 2015 06:33 PM
moparbay
Sep 3, 2015 12:48 PM
Aaron Logan
Sep 3, 2015 08:08 AM
