Transmission sticks
Old Oct 19, 2012 | 04:40 PM
dszx13's Avatar
Transmission sticks
Once my truck is warmed up I literally have to force it in first gear everytime an to go in reverse the gears never stop spinning so I have to kill the truck an put in reverse crank back up an go. I replaced slave cylinder today with no luck any ideas?
Old Oct 19, 2012 | 04:47 PM
Bingle's Avatar
check your clutch pedal bracket, they sometimes crack so they bend when you press the pedal and you don't get full throw on the rod.
Old Oct 19, 2012 | 04:51 PM
dszx13's Avatar
Ok will do when I bout the truck I checked tranny fluid an was full but dirty would that have something to do with it
Old Oct 19, 2012 | 05:24 PM
B-Fake's Avatar
That's a possibility. If the synchros aren't syncronizing it can be hard to shift, but (someone correct me if I'm wrong here) I don't think 1st or reverse have synchros. Still, changing the oil in the tranny can only do good so I'd start there.
Old Oct 19, 2012 | 05:27 PM
dszx13's Avatar
What weight gear oil an how much?
Old Oct 19, 2012 | 07:23 PM
B-Fake's Avatar
I think it's 80-90 and around 5 quarts, but I'm not positive on that. Make sure you get it with the PL-5 or GL-5 or whatever it is additive for synchromesh gearboxes. The FSM can tell you, I don't have mine handy right now, but if you don't have one someone else here will know.
Old Oct 19, 2012 | 07:55 PM
gottadog's Avatar
Best thing I did was put redline mt90 synth (GL4) gear oil in my w56. Previous owner had some thick oil in there and it shifted like crap. New oil and it is good as new.
Pull back the carpet and see if the master is leaking. Its worth checking out. Def check the pedal bracket, I welded mine before I did my swap.
Amazon Amazon
Old Oct 19, 2012 | 09:06 PM
rokblok's Avatar
Be sure you verify which lube you need. GL-4 or GL-5. GL5 can sometimes do some damage to the soft(brass) metals inside the trans. The additives in some GL5 lubes will corrode the synchros into oblivion. From what I have researched Redline MT90($$) is the best GL4 out there, which is what my swapped '87(?) W56B calls for. I have Lucas 75W-90 GL-4/GL-5 in there now and it shifts ok, but a little clunky sometimes. I will be doing MT90 very soon to see if there is a difference. Good luck!
In regards to your question, I 2nd the notion to check the clutch master. Sounds more like a clutch not entirely disengaging issue.
Old Oct 20, 2012 | 03:42 AM
Pat8942's Avatar
If the gears keep spinning when the clutch is pushed in, gear oil weight and syncros have nothing to do with it, It more likely the bracket that Bingle spoke of or the master cylinder is bad.
crammit442
7
Nov 29, 2017 12:30 PM
Marsheen
Feb 17, 2016 12:29 PM
chuckross1957
Sep 7, 2015 09:34 AM
bfmcelroy
Aug 18, 2015 06:42 AM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
