Thermostat Info
Old Oct 24, 2012 | 12:08 AM
falcon5nz's Avatar
Thermostat Info
Gday all,
Doing the water pump on my truck (RN85 22R) Pulled the tstat housing and tstat to flush the system. Well found that the gasket is pretty well shagged e.g bits of it missing, stretched, and the tstat itself appears to be stuck 2-3mm (5/64"-1/8") open.
It appears to be stock (Stamped "Kuzeh 93K 88°c") so I'm going to replace the gasket tomorrow with a Tridon TTG34 (assuming I can find one)
My big question is When cold, should the thermostat be completely closed? (I assume so) If so I'll replace it with a Tridon TT240-192 (Tridon is an NZ parts company, stocked in most parts stores hence my using their kit)
Old Oct 24, 2012 | 04:54 AM
rattlewagon's Avatar
Yes, should be completely closed when its cold.
kawazx636
Oct 6, 2021 03:03 PM
91yotapup
3.4 Swaps
Mar 5, 2019 10:41 AM
buckz6319
Aug 5, 2017 03:50 AM
wberry85
May 17, 2016 05:45 PM
White Stripe
Oct 6, 2015 10:47 AM
