Clutch Valve Question
Old Oct 10, 2012 | 11:27 AM
jnew911's Avatar
Hey all. Quick clutch valve question. I"m not sure if that is the right term for the part but it is the part that pushes the clutch fork. Anyway the rod is fully extended and I can't get the valve mounted to the trans because I can't push the rod back in. Anybody know how to do that?
Old Oct 10, 2012 | 12:36 PM
wyoming9's Avatar
Red face
You might want to thinK about this a little.
If you have pressure it needs to be released!!
open the line!!! most likely where it comes out of the Master Cylinder because with the slave cylinder loose I doubt you could get the bleeder loose.
When bolted in place the springs on the clutch plate push the slave cylinder rod back in.
Don`t forget to bleed the clutch when it is all in place and tight.:jessica::jessica:
Old Oct 10, 2012 | 03:20 PM
Sturmcrow's Avatar
Not sure if it will help, but I'm pretty sure you're talking about the clutch slave cylinder. Using that term may help you search.
I really though they just push back in. Is it hooked up hydraulically? You could loosen the bleeder screw on it to relieve pressure while you push it in.
Old Oct 11, 2012 | 06:56 PM
jnew911's Avatar
Thanks guys. Yes it's the slave cylinder, and I crack the bleeder it went straight back in. Livin and learnin one day I'll know all this stuff. Thanks again.
Old Oct 11, 2012 | 07:34 PM
kornhuskerwizard's Avatar
ive installed mine without cracking the line. just have to show it whos boss...
the1998sr5
15
Jul 14, 2020 08:35 PM
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
Poppie51
Jul 23, 2015 05:03 PM
Poppie51
Jul 16, 2015 06:16 PM
