Funky SR5 Instrument Cluster Fuel Gauge
Old 10-04-2012, 02:38 PM
Kevin1988's Avatar
Question Funky SR5 Instrument Cluster Fuel Gauge
After installing the SR5 Instrument Cluster in my 1987 Pickup the fuel gauge stays up after the ignition is turned off is this normal? and today when i filled up the truck with gas the gauge was still sitting bellow 1/4 tank before i turned the ignition on and when I turn on the key the gauge goes to full tank? is it most times that everytime you turn off the ignition the gauge goes down right? like all the other gauges?
Old 10-04-2012, 02:40 PM
StewsRunner's Avatar
Mine stays up when off and takes a little while for it to rise up after filling up.
Old 10-04-2012, 02:41 PM
Kingjerd's Avatar
Mine stays put when I turn the truck off. When I fill it up it takes about 1-2 minutes for the needle to go to full tank. IIRC it has to saturate the sensor which takes a minute. I have an 88 SR5 4Runner so same cluster.
Old 10-04-2012, 04:34 PM
nightstalker's Avatar
Mine stays put when off and goes up immediately after I fill
Old 10-05-2012, 10:15 AM
stanz's Avatar
Yes, they stay put when off. If you ever take the cluster apart it's important to remember where the needle was because it stays in place even with the cluster unplugged.
gary4runner
09-24-2015 12:53 AM
rushw
07-18-2015 01:46 PM
shisha1999
07-13-2015 11:09 PM
88yodabasket
07-13-2015 01:32 PM
Tyler Cunningham
07-11-2015 10:18 AM
Quick Reply: Funky SR5 Instrument Cluster Fuel Gauge
