weird clutch noise
weird clutch noise
hopefully someone here will be able to help me out, Whenever i push my clutch in it makes a squeeking noise and it sounds like it is coming from the transmission where the clutch is, the sound is never constant it will cut in and out when it makes the noise and sometimes it makes it while i am sitting still and the clutch is not engaged. anyone know what the problem could be? thanks.
which belts? the clutch is only about two years old and theres not much play in the pedal. someone told me that it was my throwout bearing going out, but i wanted to make sure
Sounds exactly like the throwout bearing; was it replaced when your clutch was replaced? Was it OEM or aftermarket? Do you sit in traffic a lot with the clutch depressed?
hey rabbit i am pretty sure the throw out bearing was replaced when they did the clutch. i left the truck to my uncle whos a mechanic to finish while i was away at school and he told me the other day that he was pretty sure he replaced it. I do sit in stop and go traffic just about everday for about 20-30 minutes when i am on my way to school and i am turning 35s. if it is the throw out bearing how hard is it to replace? thanks
everyone i talk to tells me it is the throw out bearing so I am going to start on taking it out tomorrow and go ahead and replace the clutch while i am in there and have everything out. What i plan on doing is dropping the transmission with the transfer case still together and just disconnecting then rear drive shaft. I think this is the easiest way to do it, any opinions?
justdifferentials
Just Differentials
14
Sep 24, 2017 08:32 PM
