Intake manifold crud removal
Old Jul 6, 2006 | 02:52 PM
Tigerstripe40's Avatar
There is a bunch of crud on the inside of my intake manifold. There is a GOOD thick coating of this on there. I don't care so much about the outside.
I am trying to figure out how to get this off.
The manifold is aluminum, so I can't juist soak it in caustic soluition.
Should I try soaking it in a pan full of diesel fuel for a few days?
Thanks!
Old Jul 6, 2006 | 02:56 PM
Chuki's Avatar
carb cleaner, and or engine degreaser work fine.
I used engine degreaser (foamy Engine Brite), and sprayed and hosed it off with a washer. Looks brand new now.
Old Jul 6, 2006 | 02:58 PM
04 Rocko Taco's Avatar
WE had some industrial engine degreaser at the shop where I used to work on mercedes, and what we would do is run it up to operating temp, coat it VERY heavy with this spray degreaser foam, and then let it sit for 5-10 minutes and hose it down with a pressure washer....Always worked GREAT!!!!
Old Jul 6, 2006 | 03:01 PM
The crud is on the INSIDE of the intake runners.
Old Jul 6, 2006 | 03:41 PM
95RunnerSR5's Avatar
get a wire wheel and stick it on the end of a drill ( a small one) or use a wirebrush or you can tie an old shirt on a drill bit and spin it in there with carb cleaner on it
Old Jul 6, 2006 | 03:53 PM
midiwall's Avatar
And you can't shoot a can of intake cleaner into there 'cause...?
Old Jul 6, 2006 | 04:00 PM
Elton's Avatar
i made a thread about how to clean it
Old Jul 6, 2006 | 04:19 PM
ChickenLover's Avatar
I always spray a bunch of carb cleaner down each runner, stuff a piece of an old shirt all the way down it (nice and tight), then get a drill caught up in the shirt and spin it 'till it's clean.
Old Jul 6, 2006 | 05:04 PM
Bumpin' Yota's Avatar
I just had a machine shop port and polish mine and whola its clean and bigger! hhehe
Old Jul 6, 2006 | 09:54 PM
trythis's Avatar
I used 3M throttle body cleaner, pricey, but the carbon melts away.
ksmudrunner99
Aug 7, 2015 06:46 PM
Flossy
Aug 5, 2015 05:14 PM
whereAreMyPants
Jul 22, 2015 03:32 AM
87blyota
Jul 10, 2015 04:31 AM
