Shaky 2nd Gen Hoods Solutions
Old Jul 7, 2006 | 08:05 AM
da_bigg_wigg's Avatar
Does anyone else notice how flimsy the hood seems at highway speeds? The thing just shakes and does its own thing. Anyone do anything to solve this annoyance? I guess it is just nit picking, but getting asked if my hood was about to fly off was the last straw... Solutions?
Old Jul 7, 2006 | 08:52 AM
mastacox's Avatar
Mine seems rock solid...
Have you checked where it's shaking from? Bolts, latch, that kind of thing?
Old Jul 7, 2006 | 09:04 AM
Tofer's Avatar
Sponsor
ditto.
mines solid.
Old Jul 7, 2006 | 09:09 AM
mt_goat's Avatar
X3 solid as a rock. Better check your hinge bolts!
Old Jul 7, 2006 | 09:21 AM
TNRabbit's Avatar
x4 solid; nary a problem. Ditto on the hinge bolts (& latch as well)!
Old Jul 7, 2006 | 09:24 AM
gregbreakseverything's Avatar
Maybe you have the shaky hood mod all the ricers are raving about. I hear its comon on sunflowers. ha
hope you get that fixed, I hate it when your wondering how long its going to take before the hood smashes in your windshield.
Old Jul 7, 2006 | 10:30 AM
Flash319's Avatar
There are some rubber stoppers that the hood runs into when you close it. They may need to be jacked up so they hit the hood. They're on bolts.
Old Jul 7, 2006 | 10:36 AM
Buck01's Avatar
My hood shakes on my 94 truck...I just ignore it.
Old Jul 7, 2006 | 10:41 AM
mt_goat's Avatar
Good point!
Old Jul 7, 2006 | 10:56 AM
its not that it shakes. its like the material is flimsy. i dunno, ill look into the bolts, but i just get the impression that its made of tin foil sometimes.
Old Jul 7, 2006 | 11:03 AM
mt_goat's Avatar
Maybe it was wrecked and they stuck a cheap aftermarket hood on there.
Old Mar 7, 2011 | 08:24 AM
WHAHAHAJR's Avatar
My 92 shakes. The hood has separated from the frame. I guess the foam or glue has came loose.
Old Mar 7, 2011 | 08:38 AM
JonnyBoy's Avatar
Separated from the reinfocements underneath is also a possibility, but I even have a hole in my hood and a fair amount of the bracing cut away to fit the 3.4 swap, and I still don't have any flimsiness of the hood.
Now the '89-95 fiberglass hood that someone threw on my '83 when the original got damaged...that one flops all over the place at 35 mph.
Old Mar 7, 2011 | 01:40 PM
tim a.'s Avatar
I had a horrible rattling at idle.Took all kinds of stuff off until I figured out the reinforcment separated from sheet metal on hood.Take off hood,spread some weatherstrip adhesive into the frame to metal contact areas,turn hood flat side down to ground and put some heavy stuff on it.Let it dry and you good to roll.
Old Mar 7, 2011 | 01:47 PM
rattlewagon's Avatar
^ My 87 hood shacked because of this.
Old Mar 7, 2011 | 02:16 PM
WHAHAHAJR's Avatar
Was planning on doing this but with some liquid nails. Since I have some already.
Old Mar 7, 2011 | 02:18 PM
92 flatbed's Avatar
Tiger's Hair would be better....
Old Mar 7, 2011 | 02:39 PM
vital22re's Avatar
totally a bro
sometimes the adjustment bushings aren't set right allowing the hood to rattle a little bit. But this is if the latch isn't properset either.
Old Mar 7, 2011 | 02:44 PM
Tofer's Avatar
Sponsor
Tigers blood.. Duhh... Winning!
Rasteirinho
Nov 6, 2017 03:40 AM
rocket
Jan 21, 2016 05:03 PM
vanion2
Jul 29, 2015 06:17 PM
nonstop
Jul 24, 2015 06:29 PM
Steezy96yota
Jul 6, 2015 10:00 AM
