another 88 4r rear window problem
Old Jul 10, 2006 | 11:48 AM
ikoror's Avatar
Lightbulb another 88 4r rear window problem
Ok,this is my "not-so-common 1st gen 4runner rear window problem":
My rear window allways went smoothly down and then didn't go up(I used inside switch and also key).
Funny is that-periodically after 30 attempts(or when it has a bad day about 60) it will go finally up and then works smoothly again for a while. So I started to go at my work earlier-I go through "gate-car-cargo-check"(window must go down ), stop at inner parking area and then click up/down for ten minutes :cry: .
But this is not definetely good solution...
I'm not good at "electric wirnig stuff", so I used not so-sophisticated troubleshooting methods:
1. As I wrote, I used key and then also inside switch(with motor on and also off)-no difference
2. Check "windows lock" switch and fuses -no problem here
2. Allways there is "click" sound in the up and down positions - from relay behind the side panel next to the rear seat on the driver's side - so I checked this relay and wires (visual) and clean all the stuff-no change
3. I checked also shell interlock bolt and rear wiper (window go down so there shouldn't be a problem, but I checked it too)-no change
4. I opened tailgate and lock with screwdriver left safety switch-tried use key with various tailgate positions-no change
5. Then I opened the tailgate hatch and inspected mechanism, all connections, ground in the gate, sprayed it-no change
6. Then I tried bang-smash-slam the door,(but I convinced myself once again that this is Japanese car-not Russian... )
Finally I came back to old "click up/down" technique(with opened tailgate hatch) and after "few" minutes windows went up. And when I turned key I noticed a delayed (after 2 second) gentle click in the rear window motor.
So after all I sucpect rear window motor-in 3 days I'll check it with my "electric-wiring-capable" friend...I'll update this thread...
If anyone has similar problem, please refer your experience.
Old Jul 10, 2006 | 04:19 PM
1989toy4wd's Avatar
For some reason it sounds like the window has jumped the track or something... just my $0.02
Old Jul 12, 2006 | 11:01 PM
ikoror's Avatar
Lightbulb Solution
Thanks to 4crawler:
http://www.4crawler.com/4x4/CheapTri...arWindow.shtml
I found that rear window motor hasn't electric current(when I switch "up" with key or button)-so I turned back to the relays (behind the side panel next to the rear seat on the driver's side) and "up relay" was lightly loose.
So I tightened it with electric tape and window now works fine ...
Old Jul 12, 2006 | 11:06 PM
bob200587's Avatar
Take it to somebody sober.
Old Jul 13, 2006 | 12:58 AM
ikoror's Avatar
It's hard to find someone...
Jun 1, 2021 01:51 PM
icentropy
Jul 11, 2015 07:21 AM
Jnkml
Jul 6, 2015 01:20 PM
coryc85
Jul 6, 2015 04:07 AM
