Fitting aftermarket horns?????
Old Jul 3, 2009 | 06:02 AM
McQuaid's Avatar
Anyone fitted some stebel magnum horns at all??? ive got mine ready to install, i was all ok until i removed my old horns and noticed that the connection only has one cable going into it??? what do i do now?? how do i wire it?
Old Jul 3, 2009 | 08:54 AM
Elton's Avatar
its cause the factory horn is self grounded to the bracket ... pretty much all the one wire does is supply power gonna need to either cut it off and wire in 2 leads to go to both horns then run the ground wires where ever u want
Old Jul 3, 2009 | 09:06 AM
4Crawler's Avatar
Actually, it is the opposite way, the horn has constant power on one wire then the horn switch supplies the ground connection to make the horn work. The factory horn is not grounded. At least this is the way my '85 is wired.
Most of the aftermarket horns are set up with the ground via the mounting point to the body and power to make them work. So to hook one up to a Toyota, you need to insulate the horn from the sheet metal ground. Then hook the horn base to the ground wire from the horn switch.
Old Jul 3, 2009 | 09:10 AM
Elton's Avatar
mine seems to work all i did was take the wire to the plus side and then run the ground
Old Jul 4, 2009 | 12:15 AM
McQuaid's Avatar
ok, heres what i did, my new horns also came with a relay, i being the ignorant person i am...i ignored this relay....my 4runner has 2 horns, one at eachj end of the radiator, i took the 2 horns off leaving me with 2 connections, 1 at each horn, i snipped those connections off and put on 2 spade connections so they fit onto my new horns, then i got a stretch of wire and cut it in 2, one length for each side, put another 2 spades onto 1 end of both cables and connected them onto the other connection on horn, then routed them up to the negative on each battery, and my horns are working perfectly.....you think i was right to ignore relay or should i use it??? im thinking..if it aint broken...dont fix it
Old Jul 5, 2009 | 04:44 AM
ovrrdrive's Avatar
The horn on my '95 is 12+ switched. When I put the air horns on the truck I just extended the stock horn wire back to the air solenoid and it works fine.
I searched to see what horns you had and found this review:
http://www.webbikeworld.com/motorcyc...stebel-magnum/
Is that the same one?
Do they seem any louder than what they measured in the test?
I would be comfortable running those without the relay because chances are the stock setup uses one anyway.
By the way, if you're looking for loud horns, air horns are the way to go. I guarantee mine are at least 140db if not closer to 150. I have had people swerve off the road before when I blew it at them (although they deserved it).
Old Jul 5, 2009 | 10:27 AM
Elton's Avatar
i have the stebel nautilus compact air horn on my motorcycle and my truck plenty loud
Old Jul 6, 2009 | 01:11 AM
McQuaid's Avatar
yeh thats my new horns, their great, the shop i bought them off are claiming their the new 139db magnums, one of them is high tone and one of them is low tone, together they sound great
do you reckon cuz i have the negative routed straight up onto my negative battery terminals this could affect the batteries holding charge??
rusty904
Mar 27, 2017 05:20 PM
Curbstomp336
Aug 30, 2015 07:20 AM
ia02
Aug 20, 2015 11:04 AM
jimkoz26
Aug 5, 2015 03:15 PM
Suprarossa
Jul 6, 2015 05:21 AM
