3.0 head bolt torque
Old Jul 5, 2009 | 10:57 PM
92silverrunner's Avatar
Hello yotatech family,
i have been a long time reader and have gotten a ton of info over the years,and have never had a need to post a question untill now.i am not new to toyota just have a simple question.
i am currently rebuilding a 92 3.0 from the groung up,and was wondering when u guys have done head gasket jobs on your 3.0's,do you mark the head bolts to identify your 90 degree torque(like the chiltons manual says).Or do you use a torque angle gauge to identify the 90 degree torque?And what is more accurate?
P.s
posted in newbie section and could not get a answer.
Old Jul 5, 2009 | 11:28 PM
TNRabbit's Avatar
It's not that critical. I used a black permanent marker. It's MUCH more critical that you clean the bolt holes out good (I sprayed w/PB Blaster & let sit overnight, then sprayed out well with a thin blower tube & 150 psi of air). Also run your bolts slightly oiled ALL THE WAY into the holes before torquing. I also torqued mine down to the 1st 90 degree turn, then back all the way off, then torqued them down all the way.
Old Jul 6, 2009 | 04:50 AM
Thank you for your responce TNRabbit,
thats what i will do as soon as my parts get here!
Old Jul 8, 2009 | 03:16 AM
TNRabbit's Avatar
Got your parts yet?
Amer
3.4 Swaps
19
Jun 5, 2017 10:43 AM
Sep 4, 2015 09:27 AM
Coreyr384
Jul 10, 2015 11:13 AM
87blyota
Jul 10, 2015 04:31 AM
Snort
Jul 9, 2015 03:58 PM
