Help ME start my truck!!!
Old Jun 28, 2009 | 07:31 PM
dcmbsc's Avatar
94 evze . Just put a new knock sensor on it.
Will not crank after putting it all back together.
redid the timing 3 times.
They only thing not on the motor is the raditor. Would there be a sensor somwhere that would not let the motor fire with out any water in it?
Old Jul 1, 2009 | 08:53 AM
dcmbsc's Avatar
ttttt
Old Jul 1, 2009 | 09:38 AM
Lumpy's Avatar
I'm not sure where the Knock sensor is on the 3.0 on the 2re it's right near the starter. I had this happen to me once. I had to wiggle some wires in the starter and all is well. I should pull it off and clean it up but she fired up.
Old Jul 1, 2009 | 12:46 PM
Marc's Avatar
What do you mean by will not crank?
Do you mean it won't turn over or that it turns over but won't start?
Old Jul 2, 2009 | 02:32 AM
TNRabbit's Avatar
You DO have the VAFM/Intake attached, right?
Old Jul 2, 2009 | 08:47 AM
874runnersr5's Avatar
x2...
Old Jul 2, 2009 | 09:05 PM
dcmbsc's Avatar
Yes intake is on!
Its trying to turn over just wont crank up all the way.
I couldnt even pull any codes off the ecu. Cleaned the the wire ends too.
Old Jul 2, 2009 | 09:10 PM
abecedarian's Avatar
So you're saying you can turn the key to start and the engine just sets there spinning over and over and over but doesn't start? ...but sort of seems like it wants to?
Old Jul 3, 2009 | 02:33 AM
TNRabbit's Avatar
Intake is on; are all the connectors seated firmly in the VAFM/Distributor/Ignitor?
Old Jul 3, 2009 | 06:02 AM
Team420's Avatar
3vze will start and run without a knock sensor, so u either got a major vacuum leak, or u forgot to reconnect something....
bigblue82
10
Jul 6, 2015 08:27 AM
Badger62811
Jun 26, 2015 09:26 PM
slider417
Jun 22, 2015 10:18 AM
jmc88runner
Jun 18, 2015 03:39 PM
