e-locker retrofit ????'s!!!
Old Jul 6, 2009 | 04:52 PM
AZ89LONGBED's Avatar
I keep finding conflicting beta regarding which master install kit is needed for re-gearing an e-locker. I'm wanting to go with Yukon gear parts, and a retailer here only listed one part number for v-6 8", but I am nearly positive the e-lockers require an e-locker specific install kit.
Also, is it true that I will need a new flange to make my driveshaft work??
Thanks in advance!
Old Jul 6, 2009 | 04:57 PM
Tubbyfatty's Avatar
Wait for 89silverpu to chime in, im sure he will know. He has one.
Old Jul 6, 2009 | 05:42 PM
a4runnerfreak's Avatar
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
Or shoot Zuk a PM. You could also check out his website gearinstalls.com
Old Jul 6, 2009 | 06:21 PM
89silverpu's Avatar
Thanks in advance!
You will need an e locker install kit but they do use the same ring and pinion. I'm guessing you have an e-locker third already out of a Tacoma or 4runner, these have different flange patterns. You'll need a new flange. I think a triple drilled flange can be found for around 30 bucks. Mine came with one from the guy who did the gears for me.
What are your plans for the wiring harness? If you're not going to make you're own, I highly recommend 12voltguy.com for the swithc and harness, the switch and harness are legit!
If you have any other questions just ask and here's a link to my build.
https://www.yotatech.com/forums/f116...-build-183550/
Old Jul 6, 2009 | 06:31 PM
mastacox's Avatar
I'm 99% sure the e-locker 3rd has at least one different carrier bearing (on the back side of the carrier) than a standard 3rd, so the master install kits should be different. Zuk willl know, he set up my e-locker with all cryo bearings and a solid crush sleeve.
Here's a picture of the "back side" of my e-locker 3rd:
And a picture of a regular 3rd:
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
1uzRunner
63
Nov 10, 2018 03:58 PM
clok
Nov 19, 2015 01:09 PM
Patrick1976
Sep 15, 2015 11:33 PM
zz_denis
Sep 6, 2015 03:43 PM
