1995 extended cab engine build.
Old Dec 10, 2023 | 07:16 PM
White5thgen's Avatar
I’ve been searching these forums for the better part of 8 years and finally need help figuring out what the previous owner did to the vacuum system on this truck and figure out why it would never idle ( besides needing major engine work)
always had a TPS range code I think it was, I noticed some side to side throttle plate play which would make the TPS reading on my meter jump out of spec, made it very hard to get it set right, and I don’t know if the dashpot not being hooked up would affect that?
can anyone tell me what these valves are called and what I’m supposed to do with them?
This can’t be right
I see the dash pot screw is missing here
Old Dec 12, 2023 | 07:37 AM
mechkw's Avatar
If you go to your local toyota dealer, you can get like a 3d printed version of the vacuum diagrams for your make and model.
Old Dec 12, 2023 | 07:39 AM
Tried that, my loval dealership is very unhelpful with anything 2000 and older
Old Dec 12, 2023 | 07:46 AM
mechkw's Avatar
Maybe somebody here will have some pics of the one you need. Recently I had no issue getting one for my 86----from Toyota. Maybe your local is just lazy. It should be in their data base somewhere
Old Dec 12, 2023 | 02:48 PM
My local dealership is the exact example of stealership. I have found some diagrams, but nothing explains what this vacuum diaphragm with the spring screw is.
Old Dec 12, 2023 | 04:12 PM
wallytoo's Avatar
did you look for the original diagram sticker on the underside of the hood; visible when the hood is open?
Old Dec 13, 2023 | 03:45 PM
Rosespud209's Avatar
Is this a 3.0? If so, I have the vacuum chart since I just replaced all my lines a few months ago. It should match up to the one under the hood (if it hasn't deteriorated lol). The pictures also aren't clear, because it looks like they tried to bypass the system/TB? My guess is that's why the idle and TPS is off.
Old Dec 13, 2023 | 06:00 PM
my truck doesn’t have any of those stickers under the hood, it’s a 22re. all the vacuum lines that are blocked off seem to be all for the blocked off EGR system. The only thing none of the diagrams show is that vacuum diaphragm that’s screwed into the plenum with the spring screw
Old Dec 15, 2023 | 06:28 PM
Jimkola's Avatar
YT Community Team
5 Year Member
everything you have pictured pertains to EGR system, with the exception of that one valve going into the plenum. It’s for ac idle up speed and power steering
Old Dec 15, 2023 | 06:30 PM
Originally Posted by Jimkola
Did the previous owner do an EGR delete?
it looks like the full LCE delete plate kit. No resistor in the EGR plug and no code either
Old Dec 15, 2023 | 06:31 PM
so can I just plug and cap this diaphragm with the spring screw?
Old Dec 17, 2023 | 02:58 PM
prcnctoyo's Avatar
Here's a vacuum piping diagram for a 1995 RN101. Might help. If not right trim and characteristics you can change those.
https://www.japan-parts.eu/toyota/eu...acuum-piping/3
87-4runner
Jun 17, 2023 06:52 PM
thomas.tc.young
10
Jan 25, 2021 11:30 PM
Keith Lloyd
Oct 8, 2015 05:35 PM
BigSwole
Apr 4, 2012 01:16 AM
LifterCatcher
Sep 11, 2010 12:55 PM
