92 pickup, oem e locker swap
Old Oct 18, 2023 | 06:45 PM
Ooops's Avatar
Ive got a 92 pickup, and found a decent deal on a whole rear axle with locking differential out of an 01 4runner. 4:10s sane as my truck, So far ive deduced that I'll need to grind off a bunch of stuff, easy peasy. And weld on new leaf and damper mounts, also not too hard, i know its a little over 2 inches wider, so I'll need to make new brake lines, (get a new parking brake cable?). I'll put 1" spacers on the front and hope it doesn't eat wheel bearings. I have a few questions though, am i missing anything? Are the backing plates for the drum brakes the same? Will my stock driveshaft bolt up? Etc etc
Old Oct 18, 2023 | 07:07 PM
millball's Avatar
You could put the 3rd member into your existing housing
Old Oct 19, 2023 | 02:52 AM
arlindsay1992's Avatar
Swapping the third is a lot easier. Notch the housing, drill and tap two M8 holes, bolt it in.
Old Oct 19, 2023 | 12:17 PM
SoCalToyotas's Avatar
swapping the 3rd into your axle housing will probably be easier, then you get to keep your track width too
Daniel Fox
Jan 6, 2022 05:12 PM
Daniel Fox
Jan 6, 2022 02:06 PM
Paul22RE
Feb 3, 2018 09:03 AM
