Steering Damper problem
Old Sep 4, 2006 | 12:39 PM
Paul H.'s Avatar
I installed a new steering damper recently and although I could not get it fully seated, I thought this would be no problem. I was wrong, when turning left, the nut makes contact with a piece of metal hanging down. I tried tightening the nut to seat it but that would not work nor would hitting it with a BFH. Any suggestions? Here is a picture.
Old Sep 4, 2006 | 02:02 PM
DirtCheap's Avatar
Try a small grinder to clear the contact area.
Old Sep 4, 2006 | 03:07 PM
Paul H.'s Avatar
So it will be alright to grind down that piece of metal?
Old Sep 4, 2006 | 03:13 PM
DirtCheap's Avatar
I, would but only take off enough to clear the bolt.
Old Sep 4, 2006 | 04:26 PM
breknraj's Avatar
Paul,
I think that if you were to remove the mounting bolt, get the right size die, and make some more theards on the castle nut side, you would gain the clearance you need, and snug up the connection on the mount.
If that isn't enough, you might be able to tighten the damper side nut a little more, and then cut or grind the exposed threads to get some more clearance.
That's the direction that I would go, for what that's worth.
Old Sep 4, 2006 | 07:37 PM
Red3.slow's Avatar
When you grind it down spray the area with some paint to help avoid the rust. It doesn't appear you have any problems with that so try to avoid it for as long as possible.
Yotadawgjr
10
Aug 23, 2015 10:51 AM
terminator
Jul 27, 2015 07:13 PM
keithporter83
Jul 24, 2015 07:37 AM
voiddweller
Jul 15, 2015 03:56 PM
