Odd cranking issue on 1st gen.!?!?
Old Sep 4, 2006 | 07:38 PM
shawn's Avatar
My 88 4runner starts on the first hit ALMOST all the time. Now every now and then, it will turn over several times before it hits. Once it does, it will blow some black smoke like its loading up and then it clears up and runs and starts fine. It may sit a long time and start up fine. Then again, i may drive it a long time, cut it off, go to start it and the starting problem happens.
So, its not when its cold that I have the problem. I really can't narrow down when it seems to happen. Some one said leaking injector, coolant temp sensor, fuel pressure problem. The thing is, it just does it intermitantly.
Old Sep 4, 2006 | 11:03 PM
yota_krazy's Avatar
3.0 or 22re? your cold start injector could be getting stuck open which would cause for a rich mixture and the black smoke.
Old Sep 5, 2006 | 04:39 AM
shawn's Avatar
22re. 4cyl
Old Sep 5, 2006 | 05:57 PM
shawn's Avatar
hellooooooooo. Is anyone out there?
Old Sep 6, 2006 | 01:08 PM
leebee's Avatar
pm waskilly wabbit, he has an 85 & 87, he might be able to shed some light on this for you.
lee
bigjstang
Jun 2, 2025 03:56 PM
sandyota
Feb 4, 2021 11:16 AM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
Poncho0206
Jul 10, 2015 06:21 PM
