AC probs.
Old Sep 1, 2006 | 06:05 PM
harley_sr's Avatar
AC probs.
The ac has not worked since I bought this 4runner. Its a 93. I have a spare fan switch, I have checked the fuses under the dash (behind the glove box) and also replaced the clay looking relay/fuse under the blower motor. Any one else have any Ideas?
The fan will not blow on any speed??
Old Sep 1, 2006 | 06:06 PM
86SR522REEFI's Avatar
your switch is bad
Old Sep 1, 2006 | 06:25 PM
harley_sr's Avatar
I have 2 spare switches.. I have tried them both..
Old Sep 1, 2006 | 06:27 PM
harley_sr's Avatar
Now on the origional one, I did see a burnt spot on the plug of the harness, and one of the little fingers on the back of the switch it self. Thats what made me think the switch is bad, but like I said I have 2 spares and neither one is doing the trick.
Old Sep 1, 2006 | 06:29 PM
harley_sr's Avatar
The only other thing is my org. switch is Black in color. Now my other 2 are a off white color. The plug is the same, and they have the same prongs.. One came from my 93 truck, and the other came from a runner from a wrecking yard.
Old Sep 1, 2006 | 06:35 PM
get one from autozone for cheap, and you know its the same thing
Old Sep 1, 2006 | 06:38 PM
harley_sr's Avatar
Yeah I will give it a shot tomorrow. Just sux not having AC...
Old Sep 1, 2006 | 06:40 PM
tell me about it, ive had my truck for almost a year and a half with no ac, im just starting to get the parts together.
Old Sep 4, 2006 | 08:06 PM
Saint_Berzerker's Avatar
I looked at the FSM schematic for the ac and really the only thing in between the blower switch and the blower is the big honking resistor.
Either that resistor got blown up, or your blower motor is out. I can't really see anything else. Having burn marks though, I'd say that one of those 2 is blown.
If you have a meter, just check the resistance for that resistor. Just see if it's open (very high ohm reading).
Mine blows like crap on everything but all the way up. I took it all apart and cleaned it all up, but didn't help a lot.
Old Sep 4, 2006 | 11:00 PM
yota_krazy's Avatar
try banging on the blower motor with a hammer handle or something, sometimes if the blower motor has crapped out that will get it to run temporarily. Otherwise id check the resistor as stated above.
Old Sep 5, 2006 | 07:52 PM
harley_sr's Avatar
I found the prob. The owner that had it befor me had taken the 40amp squar fuse out when he mounted a toggle switch to run the fan. I had a friend that had a 4runner that was 1 year newer and I poped his glove box out and saw it... Guess I lucked out on that one
swerks
Aug 4, 2021 03:46 AM
SupaDupa
Aug 7, 2013 09:44 AM
MackMan83
14
Nov 26, 2012 04:08 PM
MtnGrown
Apr 17, 2006 05:21 PM
midiwall
May 8, 2005 07:08 AM
