Access to the speed sensor on a 93 truck?
Old Sep 5, 2006 | 05:45 PM
lundy's Avatar
My speedometer and odometer finally quit on my 93 manual tans truck. I've been told its a bad speed sensor in the transmission. How do I access it?
Old Sep 5, 2006 | 06:07 PM
mt_goat's Avatar
Should be at the back of the transfer case if you have 4WD.
Old Sep 6, 2006 | 06:01 AM
Saint_Berzerker's Avatar
Yeah, just where Mt goat said.
Hey let me know if you replace the speed sensor and it works. Mine's not worked for a while, then worked for a month, now it's back out again. I don't know if it's the sensor or the wire or the cluster.
Post your conclusion!
Old Sep 6, 2006 | 05:50 PM
lundy's Avatar
OK, found it. I check with the Toyota parts folks and it will cost me $220 to replace it tosee it that's the problem. Any other ways to see if it has malfunctioned? Any testing I can do on it? It's quite easy to access and remove.
Old Sep 6, 2006 | 06:02 PM
mt_goat's Avatar
Is it mechanical or electrical? (Does it have a cable or 3 wires)
Old Sep 6, 2006 | 06:13 PM
Don't go to the dealer, you're getting robbed. Look on the net or ebay.
Old Sep 7, 2006 | 08:22 PM
lundy's Avatar
Mt. Goat It's an electrical part with wires coming out.
Old Sep 7, 2006 | 08:23 PM
lundy's Avatar
found one on ebay that matched the dealer part number I was given for $45. Are aftermarket parts for this reliable? Does anyone have ideas?
Old Sep 8, 2006 | 05:19 AM
mt_goat's Avatar
There may be a test in the FSM for it then.
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
How does the plastic gear look?
Old Sep 8, 2006 | 05:11 PM
I took mine all apart and the plastic gear and everything looks perfect, but still doesn't work. I'm hoping the gear in the tranny isn't bad? Is that a possibility?
Old Sep 8, 2006 | 05:42 PM
Tdubbs05's Avatar
most likely it's electrical. my 94 runner had this happen and was stupid (noob mistake) and took it to the dealer...oh i mean stealer. definitely got robbed.
a little detail about why the sensor fails. the sensor is a plastic gear in the rear of the tranny. the plastic just wears out after time and slips.
Alex Bessinger
Jun 28, 2015 10:05 AM
ibayne
Jun 26, 2015 06:30 AM
Bru
Jun 23, 2015 06:58 PM
Mr.Black
Jun 21, 2015 10:17 AM
Mutinebullfrog
Jun 18, 2015 01:36 PM
