1987 4-runner Idle/running problem
Old Sep 3, 2006 | 07:27 PM
jimtanner's Avatar
Question 1987 4-runner Idle/running problem
My sons 4-runner will Idle good for 10/15 min. then starts Idleing rough.If we drive it as soon as we start it it seems to do good until you slow down/stop then it will not Idle good and the check engine light comes on.When I turn it off and put my jumper wire in and check the computer it flashes one time which should be normal.DOES ANYBODY HAVE ANY IDEAS???????????? HELP
Old Sep 3, 2006 | 07:44 PM
Elton's Avatar
whens the last time it had a tune up ?
Old Sep 3, 2006 | 07:57 PM
waskillywabbit's Avatar
TPS. AFM. Sounds a lot like mine would act.
Old Sep 4, 2006 | 04:56 AM
jimtanner's Avatar
reply
Everything is new.Recently rebuilt.All of that is perfect.Has been running good.
Old Sep 4, 2006 | 05:14 AM
jimtanner's Avatar
reply
Hey this is jim that got the tail gate from you.So was it your street or rock crawler that had this problem ? Did you have to replace them or what? Did you finish the crawler? how many 4-runners you have now? I thought about you when I was in T-town 2 times last week. Thanks for the reply .I will check/clean/adjust if possible.
Old Sep 4, 2006 | 05:22 AM
This was on my 85 before I rebuilt the engine...ended up replacing the TPS and the AFM...both were pretty worn out and that solved things.
I have an 85 and an 87. The rockcrawler will never be "finished".
Good luck!
Old Sep 4, 2006 | 06:09 AM
UKMyers's Avatar
Possible vacuum leak? I've seen them where after everything warmed up and the hoses got soft a leak would develop.
Old Sep 4, 2006 | 06:21 AM
jimtanner's Avatar
Good luck!
have you had it in the rocks yet??????????
coreyedwards7611
Jan 16, 2016 06:38 PM
Michael oaks
Jul 27, 2015 11:47 AM
daddio
Jul 18, 2015 10:20 AM
cgilley
Jul 15, 2015 03:32 AM
wilbertd
Jul 6, 2015 07:39 AM
