need creative transmission flush idea
Old Dec 10, 2010 | 03:42 PM
myk.grimm's Avatar
So my pickup has, what I think is a w serries, 5speed manual transmission. I was filling the transmission with royal purple 75w/90 and about to poor in my second quart when the filltube nipple not only came off but fell into my transmission case.
I pulled the drain plug off and only the fluid came out. I tried running an old motorcycle throttle cable through the drain plug out the fill hole. I tried using compressed air in both holes, shifting through all gears and still no sign of it.
I need creative ideas how to get it out without pulling the tranny and pulling the gearset out. I just got my 22re in after a complete rebuild and the last thing I want to do is pull this transmission...any tips welcome, im running out of time and money to get this truck on the road before the snow flies.
Old Dec 10, 2010 | 04:51 PM
Pool Playen Bob's Avatar
do you have access to one of those scopes that you can stick down cylinders through spark plug holes? with the little camera and a light attached to see exactly where its at?
pfft. let that transmission gobble up that plastic for a few hundred then flush it just kidding don't do that.
if it were me i'd do that if i got frustrated enough.
tight clearances so it shouldn't be to far from the fill hole. i don't even remember the bottom side of my tranny. is there a cover plate you can pull?
Old Dec 10, 2010 | 05:02 PM
DeathCougar's Avatar
Its plastic. It won't hurt the metal gears, even if it did get sucked up into them.
Old Dec 10, 2010 | 05:16 PM
myk.grimm's Avatar
no plastic covers, and no on the scope. I almost did call it a loss and fill it with fluid. Do you think the gears would chew it up if it could get caught up in them?
Old Dec 10, 2010 | 05:32 PM
Marc's Avatar
Like Deathcougar said - it's plastic, probably not a big deal.
Not sure but maybe if you remove the shifter you can can get at it from the top.
Old Dec 10, 2010 | 06:33 PM
iamsuperbleeder's Avatar
yeah I wouldn't worry about it, since it's a manual. the gears will just chew it up, and you'll never even notice
were it an auto, then you'd be in trouble, because the plastic pieces will wreak havoc all over the place in an auto trans. but, were it an auto, you wouldn't be filling it that way regardless
Old Dec 10, 2010 | 06:41 PM
myk.grimm's Avatar
Well then I haven't been led astray thus far by anyone on this forum let alone the opinion of 2 different staff members. Im just ganna go ahead and run with it and cross my fingers.
Thanks for the speedy reply guys.
Old Dec 10, 2010 | 06:43 PM
its so simple its BRILLIANT! but theres to much crap in the way to actually see in there. like where the pivot ball mounts. but its a good shot.
and its your tranny man. there is always that chance that it could take to big of a bite and get caught in the gear. and then you'll have to disassemble anyways.
the1998sr5
15
Jul 14, 2020 08:35 PM
chukarhunt
Dec 8, 2019 11:39 AM
jjrbus
Jul 19, 2015 02:06 PM
jjrbus
Jul 17, 2015 07:06 AM
Poncho0206
Jul 10, 2015 06:21 PM
