Replacing fuel sending unit
Old Dec 4, 2010 | 07:32 AM
diablo's Avatar
I bought a new fuel sending unit for my 89 pickup ($ 104.00) from the dealer. What is the easiest way to depressurize the sytem so I can drop the tank. I do not have enough room to get at the fuel pump wires while the tank is hooked up? I also do not want to bend the fuel lines while dropping the tank!
Old Dec 4, 2010 | 08:53 AM
swampfox's Avatar
It might be easier to tilt the bed or remove it. just make sure to leave a couple bolts partly threaded in on the opposite side, so the bed doesn't slide if tilting it. This is how I done it on a full size chevy and it worked well. You can use a jack on the frame to lift it after you get it tilted .
Old Dec 4, 2010 | 09:11 AM
scope103's Avatar
Remove the fuel filler cap. On a warm day (in short supply in December in Washington) the fuel vapors can put a fair amount of pressure in the tank.
You'll still have pressure in the fuel line itself, but there's not much you can do about it. Where ever you open a line to relieve the pressure you'll have to replace the seals (crush washers), and you'll lose a little bit of fuel. So you might as well release the pressure right at the tank.
Old Dec 4, 2010 | 03:25 PM
diablo's Avatar
Thanks for the replies, I think tilting the bed to get to everything or taking it off will be the route to go.
Old Apr 29, 2011 | 05:34 PM
Mr.Utah's Avatar
I am looking for a fuel sending unit also. Dealer wants $182.00 ! Does anyone know where to get one cheaper?
Charecter1
Nov 6, 2023 10:08 AM
mskalmus
May 28, 2017 07:51 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
bryan34w
Jul 6, 2015 05:53 PM
Jnkml
Jul 6, 2015 01:20 PM
