reverse light switch
Old Dec 14, 2010 | 04:42 AM
mgood's Avatar
Ok guys I have searched and I can not find what I need. I have an 86 truck with a r22 & 5 sod. Trans. I am trying to find the reverse llight switch I have two plugs going to trans. 1 goes to transfer case indicator witch is mounted near my short shifter the other is mounted on the passenger side of the transmission about halfway down from the top of the trans. Is this the reverse light switch?
Old Dec 14, 2010 | 04:46 AM
wii_tarded's Avatar
If there are two wires coming from it, I'd say yes. Though, I thought it'd be higher up on the side....
Old Dec 14, 2010 | 04:50 AM
HupDogDaddy's Avatar
Pretty sure it's the second one on the tranny. sure way to find out is remove the connector and short out the 2 wires. see if rev lights come on.
THERE YA GO
Old Dec 14, 2010 | 05:41 AM
mgood's Avatar
Ok now I feel really stupid never thought of that but it was 19 degrees and dark last night when I was trying to get it to work last night. Thanks HDD.
Old Dec 14, 2010 | 09:58 AM
Inferno451's Avatar
Just a thought, if it turns out not to be the switch, you might have the same problem that i had. Turns out a connector had come loose in the wiring for the lights in the back. The plastic wire splices that they used during assembly have a tendancy to come loose. I ended up splicing the wires and it works great now! This seems to be a fairly common problem, but super easy to fix.
Old Dec 14, 2010 | 10:09 AM
scope103's Avatar
This might help
Old Dec 14, 2010 | 10:28 AM
mgood's Avatar
Hey scope where did you get that schematic from? I have a few other problems I was going to post and that will help out alot
Old Dec 15, 2010 | 05:03 AM
well did you fix your reverse light problem mgood?
Old Dec 15, 2010 | 07:23 AM
scope103's Avatar
https://www.yotatech.com/forums/f116...agrams-223744/
Old Dec 15, 2010 | 09:12 AM
mgood's Avatar
Nope not yet had to get it running so I could bring it home last night they are calling for snow tomarrow did not want to be without a 4wd
Old Dec 16, 2010 | 04:08 AM
Well not to be a smart ass but the reverse light aint gonna help ya with the snow!
Old Dec 16, 2010 | 06:19 AM
scope103's Avatar
Don't be silly! When he slides into a snowbank, he can use 4wd to back out. But w/o a reverse light, he could get rear-ended. Never drive in snow w/o one.
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
rchavis
Jul 27, 2015 07:41 AM
TDonkey
Jul 26, 2015 10:14 AM
Johntom240
7
Jul 13, 2015 12:18 AM
madxman21
Jul 9, 2015 10:26 AM
