loping idle
Old Dec 8, 2010 | 02:48 PM
toyocrf's Avatar
loping idle
my 93 yota with a 22re began loping(jumping from 1500 to 2000rpms and back) at idle yesterday but stopped after the truck warmed up, today when i started it while it was warming up it began loping again and hasn't stopped even after the truck warmed up the only way i could get it to stop was to turn the idle screw all the down and then the truck is still idling at 1000 rpm which is to high it should be at 750 all my vacuum lines are still connected and don't look to be cracked any other ideas as to y my truck is doing this?????
Old Jan 1, 2011 | 02:13 PM
bluidvl's Avatar
I have a 89 3vze that just started doing the same after a head gasket job. I think I may have the ignition too far advanced and its doing funny things to the cold start assist, or an O2 sensor perhaps. Not exactly sure yet, but the weather should be pretty good tomorrow and I'll dig into it. I know our motors are not the same, but perhaps my efforts could provide some insight.
Old Jan 1, 2011 | 03:27 PM
toyota4x4907's Avatar
Is the coolant level full? Try burping the cooling system.
Put it in correct ignition time, turn the idle down, then re-time, then adjust idle, then time, etc, until you get it right.
Old Jan 4, 2011 | 02:58 PM
ToyMachine88's Avatar
88 22re mine does the same thing about once a month
only when i stop and idle it will climb to 2000 then drop to 1000
when this happens i clean out my throttle body and get out the mass air flow sensor cleaner and spray it into the Throttle position sensor hole on the inside of the throttle body
this always stops the idle problem it does come back about a month later but this quickfix works until i get time to work on my truck and figure out the problem
Old Jan 9, 2011 | 07:48 AM
MrHunterman12's Avatar
Anyway you could post a couple of pictures of how to clean it because mine does the same thing
Old Jan 9, 2011 | 08:53 AM
Junkers88's Avatar
Something else to look at would be that little O ring around the idle adjustment screw. I know the get hard and brittle after a while and may cause a minor air leak. Had this happen once and swapped it for a different screw with a better ring on it. I think you can still buy the O ring at a parts place.
Old Jan 9, 2011 | 09:00 AM
ok ill post some pics as soon as i can
Old Jan 9, 2011 | 04:06 PM
RBX's Avatar
RBX
you getting any codes?
scribed
Old Jan 9, 2011 | 04:44 PM
bluidvl's Avatar
OK, so I did some work to the 3vz today trying to amend my loping idle issue, and had some luck. I was getting a code 25 and 26 which could be a whole host of fuel and ignition problems, so I started isolating variables. I did plugs, wires, distributor cap,rotor, fuel filter, adjusted the idle down from 1,200 to 750ish and cleaned up some shotty wiring from the previous owner. I reset the EFI by pulling the fuse and 20 miles later all was well. I hit the autocar wash on the way home and let it idle the whole time and it purred.
Old Jan 9, 2011 | 05:04 PM
RBX's Avatar
RBX
thats great...im still getting code 31, tomorrow i will try to jumer the VC and VS lines from the VAFM directly to the ECM, hopefullu that will fix the issue.
Old Feb 15, 2011 | 04:51 PM
toyocrf's Avatar
thanx every one
toyocrf's Avatar
thanx:wabbit:
Old Feb 15, 2011 | 05:03 PM
bluidvl's Avatar
Update: I was getting code 25 and 26 and it was cured with an O2 sensor ...now my idle is a little low but I'm getting 15.8 mpg.
Blamalam
Mar 12, 2022 07:34 AM
Marsheen
Feb 17, 2016 12:29 PM
GrimWolf
Aug 28, 2015 03:36 AM
noosh
Aug 21, 2015 03:49 AM
Sarcazmo
Aug 15, 2015 08:22 PM
