aal on my 88
Old Dec 18, 2010 | 06:52 PM
runs-on-4's Avatar
aal on my 88
put on an add a leaf to my 88 4runner last night. it was suppose to add 2 inches but it add about 3.5 inches.. also my e brake light keeps coming on this was happing before i added the leaf. what could be causeing this
Old Dec 18, 2010 | 07:29 PM
waskillywabbit's Avatar
Did you put it between the right leaves? Sounds like your ebrake cable bracket needs a lift on it so its not getting pulled by the leaf spring pack.
:wabbit2:
Old Dec 18, 2010 | 07:35 PM
sebastianholmes's Avatar
he said it was doing it before the AAL. you probably have low brake fluid. and the spring should settle some over time
Old Dec 18, 2010 | 07:46 PM
irab88's Avatar
yeah, my aal's were a bit tall, but now they ride a little lower. don't worry, they'll settle a good 1" in a little while
Old Dec 18, 2010 | 08:04 PM
runs-on-4's Avatar
the light would come onn randomly as i was driving could that be because of low brake fluid
Old Dec 18, 2010 | 08:09 PM
yea mine has a slow leak in the master cylinder and when it starts getting low it comes on and oes off randomly then stays on till i add fluid. i think thats your issue. easy check, easy fix.
Old Dec 18, 2010 | 08:17 PM
runs-on-4's Avatar
alright ill have to check it thanks
Old Dec 18, 2010 | 08:19 PM
no problem! thats what yotatech is for!
Old Dec 18, 2010 | 08:27 PM
camo31_10.50's Avatar
if it's not that, then make sure your E-Brake handle is staying all the way up against the switch
mistershmi
Jan 5, 2016 11:07 AM
V_Runner
Mar 25, 2006 09:51 AM
Bob_98SR5
Jan 14, 2006 07:56 PM
baileymoto
May 4, 2005 11:47 AM
tx ranger
Mar 18, 2005 02:27 PM
