Prerunner & All 2WD Rigs Discussions pertaining to non 4WD rigs
Twisted bolt head off rear shock mount. Help!
Old Sep 19, 2015 | 08:07 AM
mistershmi's Avatar
As you can see, when removing the lower shock bolt on the rear drivers side with a breaker bar it twisted the bolt head right off. I'm attempting to install an AAL kit. I don't want to mess up the other side too! How would I fix something like this? Any help appreciated, thanks !
Old Sep 19, 2015 | 09:09 AM
Terrys87's Avatar
The easy out that are spiral are very brittle and break easily. I would not use one of those. The square type is the one I prefer but takes a little more time getting a hole drilled into it to get the square type in.
Another option is to weld a nut to it and then wrench it out.
Old Sep 19, 2015 | 11:50 AM
mistershmi's Avatar
Terrys87,
Would that work though for a bolt that's torqued in there so tight that it pulled the head clean off?
As far as welding a nut, I don't have the tools not sure it would work anyway since its recessed... But anyway I would hate to buy an easy out kit and mess it up worse ...
Could I find a replacement plate? The shock mount is welded to that u bolt plate it appears, I'd it possible to find an replacement part?
Old Nov 24, 2015 | 08:02 AM
opus's Avatar
Cut the whole thing off and make something to replace it.
Old Jan 5, 2016 | 11:07 AM
mistershmi's Avatar
Thanks everyone, i ended up taking it to the shop since i don't have the tools or expertise to drill and tap it. 1 hour of labor and new bolts + they put the replacement bilsteins on for me.
Sep 4, 2015 09:27 AM
87blyota
Jul 10, 2015 04:31 AM
Snort
Jul 9, 2015 03:58 PM
icentropy
Jul 9, 2015 02:12 PM
