Antifreeze pouring out of overflow hose
Old Dec 11, 2010 | 06:13 AM
87toyy's Avatar
We put a new rad on dads 95 4 runner 22re 5 speed. It was airlocked so he got his mechanic to fix that. Now when hes driving he can smell prestone and noticed its wet around the drain hose on the overflow bottle. So today he noticed everytime he shuts it of pretone pours out of the drain hose on the overflow bottle. Anyone know what could be causeing this? He had the bottle filled to the proper mark and also had it empty and either way it pours out. His temp gauge doesnt go up at all.
Old Dec 11, 2010 | 06:25 AM
rustypigeon's Avatar
If the overflow bottle is overflowing you could either have a bad radiator cap, or a leaking head gasket causing too much pressure in the radiator.
Old Dec 11, 2010 | 06:33 AM
87toyy's Avatar
He also said the radiator cap is always cold if that means anything. How could he tell if the headgasket is bad? Theres no oil in the coolent or or water in the oil. He was gonna put it in for a timing chain and some other work, but if the headgasket is bad mayby he should have that done too.
Old Dec 11, 2010 | 09:34 AM
toyota4x4907's Avatar
I was having this happen to me last spring. It was the head gasket.
Old Dec 11, 2010 | 09:42 AM
vang_22re's Avatar
Most of the time when I see this happen it's usually the clutch fan. Probably the oil in it thin out or running low.
Is the fan spinning freely or is it still stiff when engine is off? You want it to be stiff. If it's easy to turn then it's the oil but if it's not then it's something more major
Old Dec 11, 2010 | 11:43 AM
James Woods's Avatar
Smell the overflow bottle after it has been running, if it smells like exhaust gas than the head gasket is bad. Also, you can watch inside the overflow while it is running and look for little bubbles. If there is exhaust pumping into the cooling system, most times you wont find oil in the coolant or the other way around. Why did you replace the radiator? I have seen radiators get blown out around the hose from bad head gaskets.
Old Dec 11, 2010 | 12:09 PM
Beaniam's Avatar
Could still be air in there somewhere. Had this happen to me and ended up running the truck with the cap off for about 20 minutes letting it burp itself out while adding coolant as it would burp and the level would drop.
wberry85
May 17, 2016 05:45 PM
puddlepirate
Sep 29, 2015 08:02 PM
Matthew Perez
Sep 28, 2015 05:43 PM
taraf
Sep 25, 2015 02:57 PM
LotOMiles
Sep 14, 2015 11:45 PM
